Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-13-2007, 01:07 AM
imlowr2's Avatar
imlowr2 is gaining momentum as a positive member of FTE.
fuel gauge 56
I'm wondering if anyone has experienced this problem with their fuel gauge. With the pivot arm all the way down, my gas gauge reads half tank. When I raise it up, it goes to full and bounces back to half. This is a new sending unit. If I hook up the old sending unit, it reads normal again. The new sending unit is a 10 ohm for stock gauges. Is this what a fuel gauge acts like if the ohms aren't correct? Any suggestions are appreciated.
__________________
If your not going to do it right the first time, don't do it at all.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-13-2007, 08:14 AM
GreatNorthWoods is starting off with a positive reputation.
Yup. They have to be a match. The gauge is expecting a certain resistance to work properly and the sending unit isn't providing what's it looking for. I used an after market sender and gauge in my truck so I don't know what you need to make the stock gauge work. My gauge and sender were 33-240 Ohm.
__________________
Vern
48 F-3 Pickup
  #3 (permalink)
Old 07-13-2007, 09:48 AM
Randy Jack's Avatar
Randy Jack is gaining momentum as a positive member of FTE.
The stock gage is looking for 73 ohms full and 10 ohms empty. Either they sent you the wrong gage or that one is busted.
__________________
Randy Jack
56 F100 Street Rod Daily Driver
Growing OLD is mandatory. Growing UP is optional.
Inside every old guy is a younger guy wondering what the heck happened.
  #4 (permalink)
Old 07-13-2007, 10:13 AM
imlowr2's Avatar
I guess I can use my old sending unit because it works and reads fine. I bought the sending unit from CPP in Anaheim. They state they only have two types of sending units, mine might be the other one. The other problem is they may not return this sending unit because its already cut to fit and not new in the package. I hate having to go through several sending units to find the right one that works. Very time consuming. Thanks for your help guys.
__________________
  #5 (permalink)
Old 07-13-2007, 12:33 PM
LEckart's Avatar
LEckart is starting off with a positive reputation.
If the CPP sender is like some aftermarket units the rod that holds the float can be removed to cut/setup for your application. I assume that is what you already "cut" to fit. Maybe they will exchange just the sender portion and you can keep and reuse the float. Just a thought.
__________________
56FUN
  #6 (permalink)
Old 07-13-2007, 02:38 PM
B/B ford's Avatar
B/B ford is gaining momentum as a positive member of FTE.
Ed, I have a spare sending unit from No Limit that your welcome to if it will work. I have no remembrance of why I have it left over. Hopefully it is the one you need.
!0 ohms one way but I,m not getting a reading the other way?
#'s on top are, 1 551 004 161
226 008
VDO MEXICO
I think I ended up getting a new one with my new guages, and had this one left over.
__________________
(1956 F100,street rodded )
But hey, what do I know? Uff Da!
Wayne
  #7 (permalink)
Old 07-13-2007, 03:14 PM
B/B ford's Avatar
226 008
VDO MEXICO
Correction to the above: I am getting a reading of 90 ohms full and 0 ohms empty.
It is a VDO instruments fuel level sender kit P/N 226 008
__________________
Wayne
  #8 (permalink)
Old 07-13-2007, 06:49 PM
imlowr2's Avatar
I appreciate the offer Wayne. I just got off the phone with Jeff from CPP. I checked the ohms on the sender he sent me. At bottom, .05 at top .55. The sender in my truck right now, I forgot the reading at bottom, but the top is .126. So the sender is definitely wrong. Your .90 will more than likely work and it seems I have an aftermarket fuel gauge rather than the original gauge that came with the trucks. Anyways, CPP is going to send me the correct one I believe it's a .90 like Wayne's. I had to pay $40 for the sender unit which is not bad, and I can send theirs back when I get the new one. I had to modify the one they sent, so I may not be able to send it back. You learn the hard way. I should of checked the ohms in the first place and I would of avoided all this. The stereo shop around the corner checked the ohms for me, but I think I better invest in a digital ohms meter instead of guess if my guage is stock or aftermarket and what the ohms might be????. Thanks again everyone for your help. I'll let you know how the new sender tests out.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
