Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-12-2007, 11:27 PM
Broken40's Avatar
Broken40 is starting off with a positive reputation.
missing some stearing components
I have a 73 f100 with manual steering....i am missing one of the peices that hold the steering shaft into the steering box and i have very loose steering. Does anyone know where i can get replacements....i have already checked all the junk yards n stuff like that....anymore ideas...thank you.
__________________
4wd 73 F-100 390 FE, 7" lift
WARN hubs 4 bbl Eddies Carb
2wd 79 F-100 351W, C-4 tranny. 4 bbl Eddies carb
"What doesn't kill ya only makes you stronger"
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-13-2007, 09:07 AM
ubereal2's Avatar
ubereal2 is starting off with a positive reputation.
I'm in the same boat with finding parts for my 79. A place to try is LMC truck, in kansas. They'll send you a free catalog, I have bought a few things from them and have had good luck.
You can get the catalog at www.lmctruck.com
  #3 (permalink)
Old 07-13-2007, 09:34 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Quote:
I believe you need the steering coupler. It's easy to find, and is still available from Ford. If the entire steering coupler was missing you wouldn't have any steering control. You prolly have a steering coupler that is coming apart, and is missing parts of the rubber isloator.
DRIVING THE TRUCK IN THIS CONDITION IS VERY DANGEROUS TO YOU AND OTHER MOTORISTS.
If the coupler breaks apart, you will have NO steering control!!
C9UZ-3A525-A Steering Coupler
Fits all 1973/74 F100/350 2WD; and 1975 F100/350 2WD with M/S. (also fits 1969/72 F100/350 2WD)
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #4 (permalink)
Old 07-13-2007, 10:20 AM
Broken40's Avatar
no it's not a steering coupler...it is a peice that is very small and is square and fits on the bottom of the steering shaft...it almost looks like this....just click on the link to see my artistic paint abilities
http://i153.photobucket.com/albums/s...oken40/fte.jpg
__________________
  #5 (permalink)
Old 07-13-2007, 10:33 AM
Ford Parts Guru
http://i153.photobucket.com/albums/s231/rewsbroken40/fte.jpg
The end of the steering shaft where it bolts to the coupler has a circular flange that is wavy, with 2 bolt holes, and 2 notches. I see nothing that matches your description. Above the flange is the gear shift selector lever(s). Are you sure the part you need isn't part of the (broken) coupler? The coupler bolts to the flange, the other end is splined where it attaches to the input shaft.
There's nothing else, because the flange is part of the steering shaft. Turn the wheel, the shaft turns the coupler, which in turn, turns the steering gear input shaft. What else is there? Nothing.
Whoa!
WARN HUBS?
This is a 4WD !!
You made no mention of this.
Quote:
I have a 1973 F100 with manual steering.
No wonder my hair is turning gray!
Didn't you see where I posted the steering coupler part number and stated 2WD??
A 4WD uses an entirely different steering set up.
btw = It's Friday the 13th...
__________________
  #6 (permalink)
Old 07-15-2007, 04:13 PM
Broken40's Avatar
Sorry my bad i just added that to my signature, i should have included that originally huh...sorry...but yeah it is a manual steering, manual tranny, manual everything, even brakes...4 drums and the whole ball of wax...but that's a different story....that peice that i need is very vital to the steering stability.
__________________
  #7 (permalink)
Old 07-15-2007, 11:02 PM
Broken40's Avatar
hey mil1ion can you post a picture of this from your collection of peices thank you...
Section 35, page 4
__________________
  #8 (permalink)
Old 07-16-2007, 01:40 PM
Mil1ion is starting off with a positive reputation.
  #9 (permalink)
Old 07-16-2007, 03:15 PM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
He's talking about the lower/front steering shaft u-joint - the one that connects to the steering box.
I remember it oh-so-well...
It's not a "u-joint" per se, but close enough of a description.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Volant CAI, eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #10 (permalink)
Old 07-16-2007, 05:09 PM
Broken40's Avatar
okee dokee i finally have a picture of the peice that i need thanks to dummy and mil1ion...here is what i need....3c668
__________________
  #11 (permalink)
Old 07-17-2007, 10:30 AM
Broken40's Avatar
does anyone have any ideas how i can get that part...any help would be greatly appreciated...thank you.
__________________
  #12 (permalink)
Old 07-17-2007, 10:48 AM
Ford Parts Guru
C6TZ-3C668-A Steering Column Shaft U-Joint Bearing (uses 2 per vehicle)
Fits: 1966 F100 4X4; 1967/77 F100/150/250 4X4.
Part is obsolete.
FTE sponsor Green Sales doesn't have any, but you might contact them anyway, because they are on a national obsolete parts network.
Green Sales, Cincinnati, Ohio = 800-543-4959. Maybe they can find them for you. Call them....give them the part number.
Dennis, thank you for posting the illustration.
__________________
  #13 (permalink)
Old 07-17-2007, 02:23 PM
This part ?
  #14 (permalink)
Old 07-17-2007, 03:32 PM
Broken40's Avatar
no sir i need the part.....3c668
__________________
  #15 (permalink)
Old 07-17-2007, 03:41 PM
krewat's Avatar
Broken40, unless someplace like LMC has the part (I doubt it), I think you're going to be buying a new steering shaft.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
