You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Properly produced Biodiesel should require no modifications. WVO and SVO DO. You would have better luck posting in the 'Bio' forum.
Take Care
__________________
('00 Ford Excursion, V10- TRADED) '05 Limited 6.0L , Air Lifts, 3.73LS, High Idle Mod., towing '00 Holiday Alumascape 31 SKS with a Hensley!
Speaking from experience....I gave it a shot for 10,000 miles in my Kenworth. Fuel mileage decreased 6 %. Short of making someone FEEL better about the environment,its not what it was cracked up to be. Anyway,noone would use it if it wasn't so heavily subsidized by the government.
Nothing for Biodiesel. If you want to run WVO you need to install a heated fuel tank system.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
differences are B20 is 20% biodiesel and 80% petro diesel and B99 is 99% bio and maybe 1% petrol diesel. Better is questionable, depends type of answer. the B20 will of coarse give you the benefits of running bio in added lubrication and will clean your fuel system and should improve your fuel economy. B99 might hurt your economy slightly (I don't see it with mine but many say it does) but had the benefit that darn little of your money is going to the middle east.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
The only place around here has B99 but I have the Superchip and it is set on the 3rd stage so I'm pretty sure my fuel economy would go down but I think it would go down a whole lot. Do you also need ot get a new fuel filter? I see a bunch of people saying that. If it cleans the fuel system then why would you need a new filter, or will the filter just catch all the stuff from the system? Thanks.
you will want to keep a new fuel filter with you because it will clean out the fuel system and the filter better catch it but that will plug it if your system is really dirty. but once you have gotten it cleaned up then the filter changes will go back to normal
As to the economy I get around 16-17mpg on #2 diesel get 17-18on approx B25 and around 16-17 running B100 so you can see it really isn't changing my economy much.
__________________
Rob
So could I jump right into filling my tank with B99?
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
I respectfully disagree, I've been making and using biodiesel for 4 years, and Have noticed a slight increase in fuel milage. Some people have said they see no differance at all. I run a 3,000 acre wheat ranch with biodiesel only and will NEVER go back to dino-diesel! All my diesels run smoother, quieter, with 0 problems in the last 4 years. My fuel costs less than $1 per gallon, and my $$$ stay on the ranch and don't go to some "rag-head" !
If you want to find out more about making and using biodiesel you should go here first: http://www.biodieselcommunity.org And look at past threads on this forum, there are lots of us here sharing info on making bio.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
I dont know what you expected so I cannot address that issue; however, the advantages to BioDiesel are not better fuel economy or cheaper fuel. The big advantages ares reducing our dependance on foreign oil, putting one of our national resources (our farmers), back to work, and simultaneously reducing greenhouse gasses.
Anything we can do to reduce the flow of cash to the terrorist supporting middle east regimes is beneficial. Anything we can do to reduce our dependence on foriegn sources of a vital resource is beneficial. Anything we can do to put folks to work is beneficial. In the short term it may cost more to operate a fleet of vehicles on BD but long term we (the nation) win and each individual benefits.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
