Does a Pilot Bearing need to be lubricated?
I am replacing the pilot bearing on my 85 F-250 2WD with a 300/4.9 motor and need to know if the pilot bearing has to be lubricated. I purchased a cheap clutch set from the Zone and the pilot bearing does not seem to be lubricated at all. I have asked a couple of people that say yes, pack a little wheel bearing grease in it, but not to much. Is this correct, or is there a better choice?
on
I've always pre-lubed them with White Lithium. Even when replacing something from the 40's. The only time the bushing is used is when ya are sitting in gear with the clutch in an engine running like at a stop light. Or for a split second when shifting. So unless ya sit at a light for a few minutes with the trans in gear the bushing never gets hot. And heat kills. So shifting to neutral at a long light will give the bushing the longest life and may well outlast the rest of the rig. It's main function is to support the input shaft and the weight of the clutch. If it needed to serve as a brg than there would be a brg there instead of a bushing. Setting for just a minute or so with the clutch in is hard on a lot of parts.
Originally Posted by srercrcr
What does your Chiltons say?
Sorry my Bad. The brg should be sealed and already greased.
If it is as Bill said than I would grease the needle brg.
I thought about it, and edited my post...it's a sealed bearing...also used 1973/79 exc on 360/390 equipped trucks.
I've only ever seen a bushing or a sealed brg. When I think of a needle brg I think of one like is used on the front spindle on 4X4's.
