Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-12-2007, 08:37 AM
badassbronco2 is starting off with a positive reputation.
i have a 87 ford bronco2 with duel flow masters dumping right out of the mufflers and when you let off the throtle it back fires i tought it was out of time but i checked it it wasent any answers
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-12-2007, 08:40 AM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
Hi, and welcome to the forum!
I split your post and gave it it's own thread...it'll get more attention that way rather than tacked onto the end of an existing unrelated thread.
Check to see if any codes are present. If you don';t have, or have access to a code scanner, you can still check the codes without one. See here:
http://fordfuelinjection.com/?p=13
And here's an explanation of what those codes mean:
http://fordfuelinjection.com/?p=14
Also, pull the vacuum hose from the fuel pressure regulator (this thing):
and check for the presnce of fuel. There shouldn't be any. If there is, it means the diapragm inside it has gone bad and it's sucking some extra fuel through the vacuum lines, and the fuel pressure isn't being regulated properly.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
