Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil and Lubrication
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Oil and Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-12-2007, 01:06 AM
psquare7575's Avatar
psquare7575 is starting off with a positive reputation.
Change FROM 20w/50? 460
My 79 F100 2wd has a 78 Lincoln 460 in it (70K miles). When I did the swap (7 years ago) My father insisted on running 20w50 in this truck (said it was for longevity).. So did the new owner. I bought it back a few weeks ago. I'm going to do an oil change this weekend.
On the highway on an 80 degree day, oil pressure is around the "A" of normal (sorry, no numbered gauge, just the factory gauge). I can't say if the truck uses any oil, but it doesn't have any blue smoke and the bottom of the engine appears fairly clean with a slight film here and there, no massive leaks.
This is a 3 season truck, daily driving/tow once or twice a year/dragstrip once or twice a year.
What oil should I run? If I change to 15w/40 Rotella will I hurt anything? Should I run something thinner?
__________________
75 H/O Project: Revival
78 Mercury Cougar XR7 523/c6/3.55:1
79 Ford F100 XLT 2WD 460/c6/3.55:1
93 Cavalier Z24 Clone
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-12-2007, 10:45 AM
jimandmandy is gaining momentum as a positive member of FTE.jimandmandy is gaining momentum as a positive member of FTE.
15W-40 would be my first choice, because it still has enough ZDDP for the older, flat-tappet cam engines. 10W-30 was probably the original spec, but they have taken out too much ZDDP, unless you can find 10W-30 Rotella, Delo, or Delvac locally, I cant.
Jim
  #3 (permalink)
Old 07-14-2007, 01:03 AM
Ed Ed is offline
Ed is gaining momentum as a positive member of FTE.
My two local Wal-marts carry Shell Rotella-T 10w30 in quart containers, 4 and 5 gallon jugs, even bulk tubs, but I am not sure what those capacities are.
Unless you have a loose or sloppy engine, minor or major blow-by, I'd use this weight and grade of oil.
It will give your engine the protection it needs, plus it will allow the bottom end of your 460, the crank, rods, bearings ect. to run MUCh more efficiently, with less internal friction. Very important for towing.
You will actually make more power, as the engine does not have that thicker oil to overcome.
Cold startup and through the warm-up cycle, will be much better as well.
I say even 5w40 oil (synthetic diesel) will be a step in the right direction for you.
  #4 (permalink)
Old 07-14-2007, 09:06 AM
For this oil change I went with 15w40 Rot T. I'll see how this goes. So far, seems ok. Long term driving will show me if it 'disappears'.
I'll update this accordingly.
__________________
  #5 (permalink)
Old 07-22-2007, 08:41 AM
Ed Ed is offline
The 15w40 is still awfully thick, for an engine that is still tight I take it? Overkill, but it's your $ that is being wasted needlessly.
Plus your oil pump is working much harder, needlessly, to pump that thick oil, when cold. I'll bet the oil is not even moving for a few seconds after your start-up.
This is why Ford never used 20w50, 15w40 as a factory fill, when that 460 was new.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
