Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-11-2007, 09:35 PM
tndiesel tndiesel is offline
Garage is empty, add now
tndiesel is starting off with a positive reputation.
WVO vs. chemical made bio
Remember I'm learning. If I convert my 97 PSD to run on WVO what is the best way to filter it and get it ready to put in my truck? I know this is a general question but I'm looking for a simple process that doesn't involve a lot of steps and is simple.
  #2 (permalink)
Old 07-11-2007, 11:34 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
Oil pump. Filter thru 1 micron bag filter. Let filtered oil set about a week or 2 in a 55 gallon drum. Pump the oil off the top of the drum into your trucks heated fuel tank. Start on diesel and when engine is hot switch to WVO. Switch back to Diesel before shutting down to purge fuel system of WVO. Smile allot when you drive past fueling stations.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #3 (permalink)
Old 07-12-2007, 02:43 AM
Flea's Avatar
Flea Flea is offline
Flea is starting off with a positive reputation.
Check out the website in my sig.
I use the Racor filter, which is a diesel filter that is rated at 2 microns or ten or twenty which all depends on the filter element you put in it.
I pump into a 50 gal. tank in the back of my truck and then it gets hot while I burn the other 50 gal. tank that is already filtered.
I use a approx. 7 micron bag to filter into the clean tank and then the fuel is heated and picked up by the racor. It then is pumped up to a switch in the eng. bay and is filtered one more time as it goes through the stock fuel filter.
Really all you do is heat and filter. The viscosity of Veggie is higher and the heat drops it to about what diesel is at so it can be sprayed into the cylinder wall.
Call GFS if you have questions. I have researched all the companies and I am really happy with their service and products. They warranty parts and installs.
They answer all my questions.
They also have DVDs and youtube.com videos on how it works.
Fletch
__________________
Fletch
________
'97 PSD 4x4 Supercab, E40D, 3.55, 113K miles,
Waste Veg. Oil conversion - GoldenFuelSystems.com
Tymar Intake,ccv mod, 3" DP,Cat delete, muff delete, Cooner 20K mod, TruCool Max Tranny cooler.
... to come
Aeroforce Terminator gauge (Thanks Tim, I have been looking for an all in one gauge).
Truck Pics
Tags
chemical, heat, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
