Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-11-2007, 06:34 PM
Josh88Ford Josh88Ford is offline
Josh88Ford is starting off with a positive reputation.
Another Bumper Build
For those asking how I built my last one, here you go.
For this bumper, I using up my 1/8" diamondplate. It is going off the same design as my first bumper, only thinner on the sides, and possible 4 inset lights instead of two. The sheets were only 4' wide, so I have to split the bumper.
I highly suggest making a cardboard template first. Find the shape of the front of the truck. THIS BUILD IS FOR 87-91 FULLSIZE AND BRONCO'S
Here are the measurements I am using
Cut your top profile out. File or grind so the edges are smooth. The front parts will be welded 90º from the top.
I am currently building this bumper, so I will be posting my progress until it is finished.
Here is one side cleaned up
Hole saw to put the inset lights.
if your starting with barely any tools, its going to be rather spendy. I am using a 4 1/2" angle grinder with cutting discs that are $1 a peice. I have already used 7-8.
  #2 (permalink)
Old 07-11-2007, 11:15 PM
Ford150/428/dud's Avatar
Ford150/428/dud Ford150/428/dud is offline
Ford150/428/dud is starting off with a positive reputation.
Hey keep up the work. and very good directions and pics.
  #3 (permalink)
Old 07-11-2007, 11:45 PM
rebocardo rebocardo is online now
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
Myself, when I fab stuff I use a sawzall with metal cutting blades and oil. I do use my 4.5 grinder with metal cutting wheels for small stuff, but, way too slow for a bumper project or making straight lines. That newer circular saw with the tung. wheel looks like a good fab tool in Northern's catalog.
  #4 (permalink)
Old 07-12-2007, 10:33 AM
Drew2010's Avatar
Drew2010 Drew2010 is offline
Drew2010 is starting off with a positive reputation.
looks good what are you making another for though. i would be glad to take the old one off your hands.
__________________
Drew Nederhoff
'96 F150 4x4 351w(5.8) 33x12.50's
Custom Made Headache Rack, Tool Box
Custom Front Tow Hook setup
  #5 (permalink)
Old 07-12-2007, 11:19 AM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold
I'm also currious why another one?
Either way, looking good so far. Do you plan on herculining this one too?
__________________
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #6 (permalink)
Old 07-12-2007, 10:18 PM
I am probably going to sell this one. I was going to see which one was better, and sell the other, but the diamondplate wouldnt go with my back one. I am trying to get some money for college. Its either fabbing stuff and selling that, or get another part time job. HMMM...
I plan on painting this one being its diamondplate.
Onto some progress..
5" hole saw. Drill press was a little too fast and had to buy two of them.
Because this section is angled, you can't weld the piping flush, because then your lights will point out angled. In this picture, this shows how I do it. The front of the bumper is straight, so going off that, push the piping out to the reference line. Then measure both sides of the piping to find how far it sticks out, finding your angle.
The inside one was only 1/4" out, So I just left it for now. I will have the outside ones pointing straight out, so I might angle the inside ones someway..
so the same to the outer..
Picture of the bandsaw
Cut
Measure the backs to make sure they are even
  #7 (permalink)
Old 07-12-2007, 10:22 PM
now that all the front peices are tach welded, time for the bottom flange. I am making mine 3".
Use whatever angle you want and tach it. BUT when you go from a 90º cut to an angled cut, you will have a gap. I gave the top part of that flange 1/2 more then the 21 1/2 on bottom, to make up for that.
Now, when I cut my angled peices, I tach the first one up, then take the second peice and mark on the first peice where to cut. 90º off the bumper..
continue you that for the last two peices.
to be continued...
  #8 (permalink)
Old 07-12-2007, 10:32 PM
nobodyspecial's Avatar
nobodyspecial nobodyspecial is offline
God, guns and trucks.
1972 Ford F-100
My Garage
nobodyspecial has much to be proud of nobodyspecial has much to be proud of nobodyspecial has much to be proud of nobodyspecial has much to be proud of nobodyspecial has much to be proud of nobodyspecial has much to be proud of nobodyspecial has much to be proud of nobodyspecial has much to be proud of
Looking good! I really liked your last bumper, and am looking to build something for my truck this fall if I can find time, your instructions will prove invaluable! Thanks!
Josh
__________________
"Drinking beer is easy. Trashing your hotel room is easy. But being a Christian, that's a tough call. That's real rebellion." - Alice Cooper
  #9 (permalink)
Old 07-14-2007, 03:00 PM
the bottom flange done
old bumper in that stage..
the next step is taking my old bumper off and making mounting brackets for this one, make a lightbar, paint it and sell it. any takers
  #10 (permalink)
Old 07-14-2007, 04:56 PM
MBBFord's Avatar
I'd be interested if you lived closer, and you made a winch set up for it.
Nice work!
__________________
  #11 (permalink)
Old 07-14-2007, 10:34 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is online now
fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE.
very slick man. you do very good work! you should think about selling some. you could easily charge $800-$1000 each esp if they are made according to customer specs!
-cutts-
__________________
My Google Photo Gallery
-96 F350 4x4 ZF5 CC/LB, 37" SSR's, D66 turbo, Stage-1's, Banks IC, 5" stacks, York OBA
-72 Bronco 302/NP435/D20/D60/10.25 welded F/R, full hydro, hydroboost, 39"iroks
  #12 (permalink)
Old 07-14-2007, 10:42 PM
captain p4's Avatar
captain p4 captain p4 is online now
I'll sleep when I'm dead
captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold
Looks great. You should become a vendor over on pirate, I'm sure you'd get a lot of business.
__________________
-Paul
-88 Mustang 5.0/5spd mild restoration in progress
-78 Bronco 460 and things
-2003 F350 Supercab shortbed FX4 6.0 PSD
Quote:
Originally Posted by STGFordCrazy04 View Post
  #13 (permalink)
Old 07-15-2007, 04:35 PM
Thanks,
That is actually the reasoning for making this additonal bumper. See if theres enough interest, and if the moneys right. I already have about 30 hours, so @ $20/hr, thats $600. I will have at least another 10-20 hours into it.
Its hard to compete with other vendors that have jigs, laser cuts and machine welded and come out selling them where you think is a reasonable price for hand building it.
I'll have to check out pirate..
  #14 (permalink)
Old 07-15-2007, 06:33 PM
captain p4's Avatar
Be careful, lol. I wouldn't post anything regarding selling it without getting a "red star" first, they'll destroy you.
__________________
-Paul
  #15 (permalink)
Old 07-15-2007, 11:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
