Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #76 (permalink)
Old 12-30-2008, 07:40 PM
meanv10's Avatar
meanv10 meanv10 is offline
meanv10 is starting off with a positive reputation.
Quote:
Originally Posted by ghunt View Post
That craftsman you linked to must be the updated version of my welder. On mine, it doesn't have a speed adjustment for the wire feed (I dunno why you'd need to adjust that on that welder anyway). On mine the on off switch is LO, HI, and OFF. Then there's another switce for MIN and MAX. So, if you do LO and MIN you can weld thin sheet, HI and MAX you can do thick stuff like 1/8" super easy.
I don't remember if mine is 20% duty cycle, I thought it was higher than that...the only time I ever had to let the welder cool off was when I was doing my subframes, because that was a LOT of welding. I could weld constantly for a few minutes or so and then I'd have to let it cool off for 5-10 minutes.
Oh, one thing to note (and I'm not sure why it's like this), my welder throws splatter EVERYWHERE. If there's one thing I hate about the welder, it's that. My brother bought a Hobart Handler and runs it with flux core wire, and it doesn't splatter nearly as bad...and it's 110V too.
Duty cycle doesn't affect the ability for a welder to produce a good weld, it is a ratting for the welder that you can run it at max settings for a certain amount of time. It is rated out of 10min so a 20% will be 2 min you can run the welder at max settings without burning it up.
the welders that were in your price range will be good for tacking only, unless you plan on only using it to 1/8" MAX, and even then no guarantees.
Also wire feed speed has a huge affect on the weld, it controls the amps that are being put into the weld, the faster the speed the more amps more amps= more penetration, but without a digital readout on a wire welder you dont know how many amps and voltage being put into the weld. the carts and numbers on the welder will get you close but things like the stick out of the wire can affect the amps and volts.
The reason that the Hobart will produce less splatter is because the transfer of welding wire to base metal is going into the spray transfer, and yours is most likely trying to operate in short circuit making causing the splatter. I have heard that by spraying PAM cooking spray on the metal and the welder will make the splatter easier to remove.
__________________
03 F350 v10
Kb supercharger
Autometer gauges
35" Baja Mtzs
  #77 (permalink)
Old 12-31-2008, 01:00 PM
Josh88Ford Josh88Ford is offline
Josh88Ford is starting off with a positive reputation.
I think you would be alright with a welder rated for 3/16 as long as you weld flat, not downhill, and all the seams welded inside and out. As I mentioned before, I would keep any frame mount, shackle mount or winch mount to a 220.
But I think the most important thing is knowing how to weld and getting the welder set right. You can have the best 220 but you could get a better weld out of a 110 if you know what your doing.
Also, another idea would be tacking the bumper up, welding the outside, grind all the welds smooth(if perferred) and have a fab shop weld all the inside. I bet they would do it for under $50
  #78 (permalink)
Old 12-31-2008, 02:45 PM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is gaining momentum as a positive member of FTE.
I strongly suggest one of these, it is cheap as far as auto-dark ones go, but bang for the buck, this thing is great!!!! Makes welding SO much more enjoyable, I bought mine as a replacement when my old beater flip-down got thrown (uuhhh-hemmm, yes it was a bad day!!) and broke. I bought this as a quick fix to get me through,,,, it is great, and I still have it. Craftsman Welding Helmet with Filter, America - Model 24400SBA at Sears.com
__________________
SEMPER FI
02/Ex/4x/7.3
96/350/CC/4x/7.3/ZF5
77/150/SB/4x/NP435
63/250/Flatbed/4x/T-18
  #79 (permalink)
Old 01-01-2009, 09:17 PM
Just make sure you can get variable shades. My Eagle Mach 1 helmet is auto darkening, shade 10 and they dont make shade 9's anymore for them. Too dark for most jobs.
I use a $30 jackson. I would suggest this helmet. Buy a shade 9 while your at it.
  #80 (permalink)
Old 01-02-2009, 11:16 AM
Proxymatic Proxymatic is offline
Proxymatic is starting off with a positive reputation.
Fun tip: Buy grinding discs on ebay, my dad got 5 grinding (not cutting) ones for 30 bucks. And got 50 cutting ones for I think $20. Sure they're from china but they last basically as long, and just as dangerous as the ones you buy from Home Depot.
Great looking bumper by the way. I'm probably going to be making a rear bumper later on after I get my truck back on the road.
  #81 (permalink)
Old 01-02-2009, 11:28 AM
you can get "tool shop"(4 1/2) brand for a little over a buck a peice at Menards here. Also, if you plan on powdercoating or painting, a softback and sanding discs is a great tool for making all the grind marks smooth. $5-10 rubber back and discs are about a buck a peice too. The sanding flat discs seem to leave lines.
  #82 (permalink)
Old 01-02-2009, 02:17 PM
Quote:
Yeah they do, I used those on my hood when I was taking some rust off of it. You can still see the lines through like 3 layers of paint.
  #83 (permalink)
Old 01-02-2009, 04:16 PM
dirtyoffroad dirtyoffroad is offline
dirtyoffroad is starting off with a positive reputation.
I built this one for a friend,he had it sprayed with bedliner
  #84 (permalink)
Old 01-16-2009, 12:32 PM
Saleenguy's Avatar
Saleenguy Saleenguy is offline
Saleenguy has a very good reputation on FTE. Saleenguy has a very good reputation on FTE. Saleenguy has a very good reputation on FTE. Saleenguy has a very good reputation on FTE.
You built a couple nice bumpers.
I am building my own in a couple months for an F350.
I think your look as good or better, than the WAY overpriced ones offered for sale from the bumper places.
Thanks for the pics.
__________________
I am Marty, Official Slackmaster #13.
Also proud to have a great wife, and 2 sometimes wonderful kids.
BC Chapter Member, also Nebraska, SC, NC, Wyoming, Maryland, NY, Mass, Oregon, NH, WI, Sask/Manitoba Chapters because the people are great....I can always join more, so if you want me just invite me.
  #85 (permalink)
Old 06-29-2009, 10:06 PM
greenbrg greenbrg is offline
greenbrg is starting off with a positive reputation.
I have some more ideas for your sweet bumpers and your nurf bars, I love LED lights and love making my truck look like a Christmas tree. I was thinking having built in LED turn signals that are both running lights and turn signals. Can you post some more photos of your nurf bars. I want to install them with the red and amber LED lights going down the side, 94 F250 super cab diesel. Keep up the great work. As far as all the welding questions, I got an old Lincoln 220 stick welder commonly called the buzz box for $50.00. That thing works great, for all the people that do not want install 220 you can unplug your water heater and or A/C to your house and plug in a 220 welder. All you have to do is go to Home Depot and get a plug adapter buy using the dryer plug with a different plug to plug in the welder to the plug that your house plug. Hope this helps and once again way to create some sweet bumpers.
  #86 (permalink)
Old 07-02-2009, 02:24 PM
Homemade's Avatar
Homemade Homemade is offline
Homemade is starting off with a positive reputation.
Wish you lived around here i want a good bumper for my truck and would love to be able to help build it .
__________________
1986 F250HD 4X4 4speed 460
1972 F250 C6 360 motor dead
1967 Mercury comet Rebuilding
2006 Ford Fusion DD
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
