Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 08-06-2007, 10:25 PM
Josh88Ford Josh88Ford is offline
Josh88Ford is starting off with a positive reputation.
put a fuel cell in it and put the winch where the gas tank use to be. you'll be able to run a fairly small bumper then..
  #47 (permalink)
Old 08-07-2007, 08:39 PM
flareside_thunder flareside_thunder is offline
flareside_thunder is starting off with a positive reputation.
Right now...the truck has a fuel cell AND the factory tank....I'll be pulling the body off and sandblasting the frame, painting it and plumbing up the fuel system....guess I oughta make some drop brackets for the bumper I got for it...nothin like 6 inch round stainless pipe to stop a train......gotta take some pics of the bumper that the winch came with...meant to before I started hackin on it....oh well, probly just drop 125 lbs off of it tonight cuttin it up......heh...so much for keepin the Bronc's tailgate.....
  #48 (permalink)
Old 08-09-2007, 04:21 PM
http://cgi.ebay.com/ebaymotors/ws/eB...m=300140300653
  #49 (permalink)
Old 08-10-2007, 03:14 PM
wileec's Avatar
wileec wileec is offline
wileec is starting off with a positive reputation.
Good luck josh that one looks real nice.I would concider it but I really do not want to run my winch on a receiver mount. Still looks real nice.
__________________
wileec
Stock 95 XLT Bronco
  #50 (permalink)
Old 02-22-2008, 12:08 AM
brazzealI6f150's Avatar
brazzealI6f150 brazzealI6f150 is offline
brazzealI6f150 is starting off with a positive reputation.
dude you wanna build a bumper for a 96 f-150?
same thing as your second just no diamond plate and 3" pipe running from the grille guard to the outside edges of the bumper.. gotta have horizontal support. ha
so what do you think? my mig is out of commision... cant afford to replace it.
__________________
totalled the dodge (by far worst day of my life)
on the upside i now own an 08 f-150 stx regular cab 4x4. all black.
  #51 (permalink)
Old 02-22-2008, 05:28 PM
if I could borrow your truck for a week for mock up and design, I would be more then happy to.
There arent any 92-96 trucks that I can get ahold of here. The body and frames are different from the 70'sto 91's.
  #52 (permalink)
Old 02-22-2008, 05:29 PM
How much did you get outta that last one Josh?
JR
  #53 (permalink)
Old 02-24-2008, 07:24 PM
$500
my current is for sale for $750 with all the lights, wiring ect included.
  #54 (permalink)
Old 11-17-2008, 10:25 PM
Kevin_O. Kevin_O. is offline
Kevin_O. is starting off with a positive reputation.
Hey, i know this thread is really old, but if your still making bumpers, i have a question. You said that this one is for up to a 91 f150. I have a 93, what's different that this design wont fit a 93. I want to make one like this because it looks great, but if i can't use these dimensions, could you tell me what i would have to change for a 93? I just really need a good solid bumper, and the stock one doesn't exactly cut it. Your design looks really good and i want to make one if you could help me out a little bit.
  #55 (permalink)
Old 11-18-2008, 03:56 PM
Kevin,
Ford started making different frame horns as they changed the new front end design. The 92-96 frame horns have the crumple zone in front(looks like an accordian) with an angle plate in the front for different mounting. The 70's-91 are a straight frame horn so the mounts wouldnt work. in other words, the up to 91 all the mount holes out be perpendicular with the front of the bumper. 92-96, two would be perpendicular and two paralell (on each side)
The dimensions would work for the most part, but the top profile of the bumper will be different because the front clip curves rather then a flatnose. Again, as i mentioned, get some cardboard and make up a bumper out of that. When I built both of my bumpers, I built them exactly the same out of cardboard as i did with metal. In fact, I disassembled all the parts that made up the cardboard bumper and traced them onto the sheet of metal to make the parts for the bumper. I wouldnt worry too much about the frame mounts until the cardbaord bumper is assembled. The mount to the frame will be the exact same, but the mounting to the bumper will be different if you have a different style bumper, body lift ect.
  #56 (permalink)
Old 11-18-2008, 05:56 PM
Ok, thanks, I just made a cardboard bumper out of your dimensions, and i'm heading out to see what i need to trim or change to make it fit my nose. I forgot that my truck was at the beginning of the more rounded body style. I guess i'll have to see how to make some mounts when i get the old bumper off. I had another thought though, the grille guard you put on yours looked good, but it looked a little flimsy on the sides. Did you ever come up with a way of reinforcing it from folding sideways, or is it sturdier than it looks. I was just wondering because i've always wanted a grille guard like that so i figured i'd make one. The problem is i work my truck hard on a farm and i didn't want to hit something and lose all my hard work breaking it off sideways. i was just curious, but it looks good and thanks a lot for your help. you do good work.
Update: I went out to see how far off your design would be, and it's not bad. It fit just golden snug on the sides, But the middle is a long ways off. I'm thinking about just taking off my bumper and tracing the curve directly from the stock one so it fits up nice to the front. There were only two mounting points i saw. The was a plate that came off the side of both of the ends of the frame rails just past the accordion section. There were two bolts on each plate going to the top and the bottom of the bumper. Time to hit the cardboard again i suppose.
  #57 (permalink)
Old 11-19-2008, 04:10 PM
your better off getting everything right with the cardboard rather then metal!
It wont collapse, if you hit something, it would probably tip the truck over before folding the grille gaurd. Make it out of 3/16 and wrap the edges with 12x3/8 flatbar if your afraid of that. You could hit it with a sledge hammer and it wouldnt budge. 1/8" might vibrate a little without the flatbar. Tack and hit it when you get a gap when you are wrapping it around. Weld downhill on both sides so you dont get any warpage. saves on welding material too. Welds on that arent that important. If your going to be beating on it a lot, i'd go with 3/16 or 7 ga instead of 1/8". Then you dont have to worry about dings and dents. As I mentioned before, 1/8" is fine for a daily driver and weekend mudding ect, but it your going to be strictly mudding or beating on it, 3/16 or 1/4 would be better. A little heavier.
  #58 (permalink)
Old 11-21-2008, 09:18 PM
stangbanger stangbanger is offline
stangbanger is starting off with a positive reputation.
Are you still building bumpers? Also what ever happend with your side steps?
-Randy
  #59 (permalink)
Old 11-21-2008, 09:25 PM
How many sheets of steel did it take you?
  #60 (permalink)
Old 11-22-2008, 03:06 PM
I made my front and rear bumpers out of a 4x8 sheet of 3/16, plus some drop.
Steps have been on for quite a while.
Also made a big push bumpers for my (now ex- mechanic) 16" tall. Uses it to push non-running cars into the shop.
never did get a chance to take a picture of the final product
thats all I have done as far as bumpers...been quite a while. No one really has interest for solid bumpers for 87-91's, just mostly 92-96
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
