2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
What kind of weight are you towing
Old 07-10-2007, 09:07 PM
Gparcels's Avatar
Gparcels
Gparcels is offline
Just curious what amount of weight you guys are towing with your new expeditions and how they are handling it. How do these things handle 7000+ pounds or would the F150 be a better overall tow vehicle. Thanks.
Old 07-11-2007, 09:34 AM
kenttrudiw's Avatar
kenttrudiw
kenttrudiw is offline
I am towing a 5000 lb 22 ft boat. Boats don't buck a lot of wind likw a caming trailer but they are still heavy!
I pulled the same boat with my 04 Exped and it pulled fine, but this 07 Exped pulls like a dream! The extra engine horsepower and the 6 speed tranny are a huge differance from the 04.
I really cannot feel that the boat is behind me except the hills or mountains. This 07 stays in the sweet spot very well, pulling up the Colorado Rockies I was going close to 60 at the top of the long grade going into the tunnel, I cannot ask for anything better than that, unless of course I wanted to drive the F-350!
Old 07-12-2007, 11:11 AM
tkd's Avatar
tkd
tkd is offline
Horspower difference between 04 & 07? I thought they were both 300hp 5.4 3v? Or did the 3v come out in 05?
Old 07-12-2007, 12:33 PM
gristanv's Avatar
gristanv
gristanv is offline
2004 Expedition
Engine Category Details
5.4L V8 260 hp gas Standard
Number of cylinders: 8
Number of valves: 16
Camshaft: Single overhead cam (SOHC)
Horsepower: 260 hp @ 4500 rpm
Torque: 350 ft-lbs @ 2500 rpm
Old 07-12-2007, 01:23 PM
kenttrudiw's Avatar
kenttrudiw
Yes, the 04 was the last of the 260 hp in 2005 the newer 3v.
With the newer power and 6 speed it is a big differace even non-towing you can tell!
Old 03-02-2008, 12:52 PM
SemperFiDevilDog's Avatar
SemperFiDevilDog
SemperFiDevilDog is offline
Towing with a 3.73 or 3.31 rear?
Old 03-03-2008, 09:03 AM
kenttrudiw's Avatar
kenttrudiw
The 3.73 rear comes with the tow package, make sure you have the tow package on the truck, before you try to tow much over 4,000lb.
Old 03-03-2008, 03:17 PM
rowekmr's Avatar
rowekmr
rowekmr is offline
I am also curious about towing a heavy load with the Expedition but I am looking at 9K and a heavier tongue weight for a 31 TT. I pulled it home empty (book says 7.5K) with my 06 Explorer Ltd with 4.6/tow pkg that routinely pulls my 8K (weighed on scale) boat in the summer with no problems or sag but I had a lot of rear suspension sag because of the heavy tongue. I bought a 00 Excursion V-10 but after making a few gas stations rich I am wondering could I trade both and get the Expedition. I could be wrong but the Excursion doesn't seem that much stronger than the 05 Expedition's I test drove a while back. I bought a 0-1000 tongue weight scale and it goes off the scale so I figure about 1100-1200 tongue weight which I think will be the limiting factor. I was wondering if it will do it without damage and although I use a weight distribution hitch is the rear air suspension mandatory.
Joe
Old 03-04-2008, 09:50 AM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
Joe
Do you have the Sherline hydraulic Scale? I've got one with the #2,000 guage and wish I had the #1,000 guage. I think you can just change the guage to 200 psi gauge and top off the oil. Perhaps we should swap scales, are you anywhere near pheonix?
http://www.sherline.com/lm.htm
Old 03-04-2008, 01:09 PM
rowekmr's Avatar
rowekmr
rowekmr is offline
Yes that is the one that I have (the 0-1000) used once still in the plastic it was shipped in. A swap sounds good PM me a way to get in contact with you. With todays gas prices it will probably be just a little bit cheaper to ship them rather than drive !
Old 03-04-2008, 06:11 PM
chuck s's Avatar
chuck s
chuck s is offline
My tongue weigh.
You can swap out the gages.
Here we are without fresh water.
-- Chuck
Old 03-04-2008, 08:45 PM
rowekmr's Avatar
rowekmr
rowekmr is offline
Oops forgot to answer I'm in Chicago. When you say swap gauges where can I get them from, does it matter the brand? And when you top off the oil how precise does the topping have to be. Won't the gauge be off if there is a little air in the resevoir?
Old 03-04-2008, 08:46 PM
rowekmr's Avatar
rowekmr
rowekmr is offline
Hey Chuck S how much do your trailer weigh and how does the Expedition handle the load?
Old 03-05-2008, 06:27 AM
chuck s's Avatar
chuck s
chuck s is offline
We weigh about 5000 pounds. The Expedition handles the load well and cruises at 65mph at 1800 rpm in 6th gear with the trailer behind on most roads.
There's a pair of Trojan T125 6v batteries and two LP tanks on the tongue. Equal-i-zer WDH (1000/10,000 pound).
-- Chuck
Old 03-05-2008, 08:26 AM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
Chuck, do you happen to have the Ashcroft gauge model #'s? At my work we buy Ascroft products so I should be able to get one at a good price.
Quick Reply: What kind of weight are you towing
