Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-10-2007, 09:25 PM
ncguy23 is starting off with a positive reputation.
What next?
I'm piecing together info on lifting my truck.
I'm 99% sure I'm picking up 3 inch lift front leaf springs from an '80 f250 to get the trucks butt in the air. My idea up front is just replacing the coil springs.
My question is, will just the coils and the new leaf packs in the rear be fine, or will this require any other modifications/replacements to be successful.
__________________
'93 f150 xlt supercab, 302, e4od, 4WD, about 130k
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-10-2007, 10:19 PM
fishmanndotcom's Avatar
fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.
front leaf packs are different length than rears. i swapped in a pair of rear packs in the front of my 85 F250 and gained about 4" (stock F150 rears with overload removed) and i had to fab some mounts. if i remember right it was about 3-4"
-cutts-
__________________
Quote:
Originally Posted by Ingolf View Post
yeah, im a rich kid. but hey, i dont hate my parents for it. my dad drives a lambo.. so what the **** do i care LOL
  #3 (permalink)
Old 07-10-2007, 10:23 PM
hmm... The fronts measured out at 53" x 3" with I think 5 leafs in it.
The rears I have now are the same measurement with 4 leafs.
Will just replacing the coil springs up front be fine?
__________________
  #4 (permalink)
Old 07-10-2007, 10:35 PM
they measured the same?
let me make sure i understand.... you are wanting to put lift springs from the FRONT of an 80 F250 into the REAR of a 93 F150?
also, take into account that lift springs tend to stretch out more than a stock pack b/c of the increased spring flex. dunno if that might be the problem but something doesnt sound right
did you measure the front springs with no load and the rear springs with a load (on the truck) ?
-cutts-
__________________
  #5 (permalink)
Old 07-10-2007, 10:39 PM
They're definetely 3 inchs wide, it was raining so I didnt feel like crawling under the truck on gravel to get an exact length measurement. Lemmie remeasure in the morning and I'll get back to you.
And yes the plan is to put front springs (entire leaf pack) from an 80 f250 in place of my rear spring pack on a 93 f150 and place new coils in the front.
call me cheap but if I can get this done for what it'll cost ($60+coils, maybe $200 total) I'll be happier than all hell
__________________
  #6 (permalink)
Old 07-10-2007, 10:40 PM
the front springs are 150 miles down the road, dude measured em unloaded center eye to center eye
__________________
  #7 (permalink)
Old 07-11-2007, 08:49 AM
cheap is the only way to go! thats why i do all my own work (minus gear setups ) b/c i can buy the tools and do it myself and come out cheaper in the long run! plus i love good quality tools!
thats cool man. i just wanted to give you a heads up that the front and rears (to my knowledge) do not match up length wise! i hope for your sake i am wrong though!
-cutts-
__________________
  #8 (permalink)
Old 07-11-2007, 09:24 AM
teds74ford is gaining momentum as a positive member of FTE.teds74ford is gaining momentum as a positive member of FTE.
Centering pin might not be in the right place, either.
Cutts, you should try gears. They really aren't that bad after you do a couple sets. Speaking of cheap: I called about a shim set for my D60 rear when I was swapping in my used gears. They wanted too much for just a shim set, so I carefully smashed and cut aluminum foil and cans to make my setup Still holding up after 4 years with a locker and 36s, so it can't be all bad
__________________
Was 2wd
  #9 (permalink)
Old 07-11-2007, 10:37 AM
Alright just crawled under and got a more accurate measurement.
Leaf pack on the truck currently (under load) measures roughly 57" x 3" eye to eye
I'm thinking unless I do new mounts I wouldnt be able to fit the new leaf packs
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
