Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-10-2007, 12:34 PM
JQ JQ is offline
JQ is starting off with a positive reputation.
E4OD Off Road Problem
I've owned my '92 F250HD 4x4 7.5L since new. The truck is stock except for a Banks intake and exhaust system.
From the beginning I've had a problem with the converter. When traveling slowly off-road (even on moderate grades) for a period of time; or when backing with a trailer up a grade, the converter overheats and spews trans fluid from inside the bell housing (not the top vent). I lose about a 1.5 quarts. After it cools, there is no leakeage of fluid. The trans temp stays normal (the guage is reading at the pressure test on the trans housing so it doesn't see the converter temp). There are no other signs of incorrect operation.
I had Banks install a Trans Command module (problem existed prior to install). I went to an oversized cooler and conducted a flow check that showed normal. Ford replaced the trans and converter in 1998 with the then latest E40D mods and it made no difference.
I've been to many trans shops and to Ford with the problem. Each time I've drawn a blank. Has anyone else had this problem? Any suggestions?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-10-2007, 04:09 PM
Help I M Stuck is starting off with a positive reputation.
you traveling in 4HI or 4LO when traveling slow offroad? 4HI will allow it to heat up and build pressure and spurt out. Using 4LO puts everything in a lower gearing and that's what you need for going slow when offroading.
__________________
-Jeff
86 Bronco II 4inch suspesnion lift, 3inch body, 35x12.50x15 BFT AT/s and 4:10gears.
05 F250 Superduty Diesel--tows the BII to the trails
  #3 (permalink)
Old 07-10-2007, 04:30 PM
drj777 is starting off with a positive reputation.
Exclamation
and i would HIGHLY recommend you add one of these trans pans to your rig...
http://www.mag-hytec.com/
it holds 2.5 more quarts than stock...AND it has a plug for a temp gauge!!
drj
i have the diff cover AND the trans pan...MAG-HYTEC produces vastly superior products to anything else ive found.
__________________
-'03 f-150 5.4L SUPERCREW 4x4 (4.56s/DETROIT/mag-hytec/icom/35s)
-'86 FSB 5.0 XLT (4.56s/headers/33s)
-'00 mustang GT (3.73s & rodded out)
-'00 XR400r
-'03 MZ Baghira 660
  #4 (permalink)
Old 07-11-2007, 06:52 PM
JQ JQ is offline
Thanks for both the replies.
re: 4L vs 4H, which gear position should be used? And, my trailer is an 8K bumper pull. If I go to 4L before backing can the transfer case take that load?
re: the extended pan, the Banks tube headers leave only 2" of clearance below the stock pan.
  #5 (permalink)
Old 07-11-2007, 07:36 PM
4LO for driving on dirt (offroad) at slow speeds. Backing? what's the problem with backing? can't you back up in normal 2wd? If it' a steep incline then i'd use 4LO backing.
__________________
-Jeff
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
