Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-10-2007, 01:09 AM
MrSKS's Avatar
MrSKS is starting off with a positive reputation.
Flame Exhause Kit ?
Hey guys, wanted to see if anyone has any suggestions on my little prolem
What I have is a Hot Licks Exhaust Flame thrower kit, it's installed on a 04 Ford 6.0..... My setup is running propane controlled by a electric air valve and I'm getting good spark and good propane flow. But I can not get it to ignite. I've tried adjusting the amount of propane and even tried it off so there is no chance of the exhaust effecting it. I can light it with a torch and it works good but can't get anything with the spark plugs.
Any thing would help.
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-10-2007, 03:55 AM
bla1879's Avatar
bla1879 is gaining momentum as a positive member of FTE.
i have no idea how to help you, but i know that when you get it fixed you should put some video or pics of that up on here, cuz that sounds freakin sweet!!
__________________
-- Brian --
'00 F-150 Triton 5.4L
Fabtech Lift
16" 51 series ProComp rims
315/75R16 Dunlop RMR
Spintech muffler
4.56 gears
Alpine iDA-X001
80 gig iPod Direct Connect
2 10" PBs woofers
2 5 1/4" PB mids
2 5x7" Clarion mids
2 1" PB tweeters
I CORINTHIANS 10:13
So-Cal Chapter Member
  #3 (permalink)
Old 07-10-2007, 05:16 PM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
Can you try moving the propane injector further behind the spark plug? My guess is your fuel mix is not coming into contact or mixing with the available air to the point it can ignite.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #4 (permalink)
Old 07-10-2007, 07:28 PM
MrSKS's Avatar
Well it's already welded in so thats a little hard, and I tried mixing air in the exhaust but still no flames. Going to play with it after work.
  #5 (permalink)
Old 07-10-2007, 08:22 PM
ReAX's Avatar
Molon Labe
One of two things are happening, either the spark is being blown out or the propane and oxygen are not reaching the spark in the right mix. You are getting a good mix at the tip.
__________________
-MECP 06/27/08
  #6 (permalink)
Old 07-10-2007, 11:28 PM
MrSKS's Avatar
Well I tried running air threw the system..... but still no go. I tried adjusting the valves on each just to see if I could get it to go. Still will lite with the torch, and man it's cool at 1500rpm or so. Looks like a big torch, but that doesn't do me any good if I can't lite it from the cab. Is there anything else I could use besides a spark plug?. And I can't get the spark plug out any farther or it'll be in plan sight.
  #7 (permalink)
Old 07-11-2007, 01:43 AM
ReAX's Avatar
Molon Labe
I would try it, just to rule it out as a problem.
__________________
-MECP 06/27/08
  #8 (permalink)
Old 07-11-2007, 03:37 AM
MrSKS's Avatar
Try what exactly?
  #9 (permalink)
Old 07-11-2007, 03:13 PM
ReAX's Avatar
Molon Labe
Mounting a spark plug at the end of the exhaust tip.
__________________
-MECP 06/27/08
  #10 (permalink)
Old 08-12-2007, 08:56 PM
MrSKS's Avatar
Well I got it working, so I thought I'd post a few pics
  #11 (permalink)
Old 08-12-2007, 09:20 PM
clunker86 is starting off with a positive reputation.
Damn I Must Say Thats Bad A$$. I Heared Of Run Your Truck A Little Rich And Mounting A Spark Plug In Your Exhust Pipe The Run A Coil To The Spark Plug And Getting It To Shot Flames. Damn I Want To Do That To My Truck. Only One Problem, I Will Have To Move My Exhust Pipes Behind My Tires So I Dont Burn Them Off The Truck.
So What All Did You Have To Do And Use To Have Fire Out Your Pipes
  #12 (permalink)
Old 08-12-2007, 11:47 PM
MrSKS's Avatar
It's a hotlicks flame kit mixed with propane. There kit won't work on a diesel with something "extra" I have a 5 gallon tank that is plumbed into a electric valve. It's wired to a 3 way switch, down=off, middle=ignitor box, third=opens valve for propane. It's best to get the spark as close to the tip as you can, and as for the propane it'll vary on the exhaust. I have to rev mine up and let it fall to light. But it also works at 75 on the highway if I drop it into neutral.
As for that I'm going to redo the exhaust and dump it out the rear. I'm also working on another system for the truck. If it works right I'll have one tank that starts the flame and the second tank will be high pressure propane/air. I want a 15 ft flame :P
  #13 (permalink)
Old 08-21-2007, 05:17 PM
v10lampert is starting off with a positive reputation.
that is bada$$ just make sure that you dont melt the a$$ end of your truck
  #14 (permalink)
Old 08-27-2007, 09:55 PM
jake00's Avatar
FTE is my crack
jake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to beholdjake00 is a splendid one to behold
thats awesome
  #15 (permalink)
Old 09-19-2007, 10:42 AM
chrono4's Avatar
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
One thing that Ive seen done is using a combo of the propane and a kerosene mixture under high pressure...
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
