1999 F-350 abs hydraulic brake booster leaking - Ford Truck Enthusiasts Forums
Old 07-09-2007, 11:09 PM
tdo tdo is offline
tdo is starting off with a positive reputation.
I have a 99 F-350 dually powerstroke and I recently noticed that I have power steering fluid coming out of the overflow hole on the bottom of my Abs hyraulic brake booster behind the master cylinder. When the hydraulic booster leaks is it finished and need to be replaced? Is there a rebuild kit? If not how much am I looking to spend on one. Also, how much of a pain is it to replace? Thanks.
Brake booster leak...is there a fix? Redagain 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-29-2015 10:58 PM
need a new brake booster Kemicalburns 1978 - 1996 Big Bronco 0 03-22-2015 02:44 PM
1977 Power Brake Challenge Hawkmcgee 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-26-2014 08:07 PM
68 F250 brake booster swap- need tech advice MY68F250 1967 - 1972 F-100 & Larger F-Series Trucks 25 04-07-2008 08:29 PM
73-79 Vacuum to Hydraulic Brake Booster conversion highway90 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-13-2005 05:13 PM
Tags
2003, 350, 99, booster, brake, dually, f350, fluid, ford, hydraulic, leaking, power, powerstroke, rebuild, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
