Dyno charts.
Dyno charts.
I have searched and searched. I probably used the wrong search terms or something, but I have come up empty handed.
I'd like to see full dyno charts for current model 4.2, 4.6 and 5.4 engines.
I'm interested in the "official" charts (crank) and the real world charts (rear wheel).
None of my brochures have this info. They just list peak numbers which are worthless to me.
I'm looking for stock charts, nothing fancy.
Back in the day, when I was into motorcycles, a dyno chart was included in every magazine test. I'm new to trucks so I don't know what publications have these charts. You'd think Ford would publish them.
A Tundra catalog I got the other day (I have no idea how they got me on their mailing list, although I did have a Tercel like a billion years ago) has watered down (and suspiciously optimistic) dyno charts but at least they are somewhat useful.
Unrelated but worth asking: I've also been searching to see if the current 4.6 engines suffer from plug blow-out, plug seize-in or anything else out of the ordinary. I'm guessing (from looking at the spark plug part numbers) that the 4.6 does not use the same plugs as the 5.4 so that might eliminate the seize-in issues. I'm assuming, and hoping, the heads have more than a few spark plug threads, too.
Finally, the newest 4.6 (248@4750/294@4000) has almost the same power today as the 5.4 (260@4500/350@2500) did when it was first introduced. Obviously, the torque figures are not close and the 4.6 has to rev higher to make the power. Does a newer 4.6 feel anywhere close to a first generation 5.4 or does the extra ~50 cubes trump all no matter what? I'm guessing them 50 cubes matter a lot. 60ft-lb at 1500RPM lower has to be a big difference.
Okay, one last thing. The 4.6 (and 5.4, although not lately) seems to be on this list a lot:
http://en.wikipedia.org/wiki/Ward%27s_10_Best_Engines
Look at 2007, 2006 and 2005. Did the recent 5.4 spark plug problems contribute to the 5.4 falling off the list? At one time the 5.4 owned the list.
Thanks for any insight!
on
Part of the problem with dyno charts:
Gear ratios, tire size, tire inflation, wheel size, 2x4 or 4x4 and bed length (which changes drive shaft length) all have an impact on dyno charts. Dyno charts are good for showing relative gain on one setup, but not for comparing absolutes for all setups.
Also, too many folks look mainly at the HP numbers... great if you like spinning your engine fast. What counts with these trucks is torque, especially on the low end.
Elevation also plays an important role as well as the ambient temperature.
As for the list I have seen it and think it is pointless, there is no reason the 4.6L should be on it and not the 5.4L or visa versa, when the 5.4L is just a stroked version of the 4.6L for all intents and purposes. I equate it to Consumer Reports giving a Mazda truck a much higher ranking than a Ranger when they are the exact same thing just with a little different front body panels. When I see things like that there is an obvious bias or just plain lack of intelligence.
on
Elevation, air temp and humidity all play a role. Dynos generally have sensors for these which is why we have graphs, and corrected graphs produced by the dyno.
Engine oil temp, engine temp, coolant temp, fuel temp and air intake track temp also are factors. One of the reasons people use fans on dynos to minimize heat soak.
Milwaukee1979F150
12-20-2009 11:16 PM
