Dyno charts. - Ford Truck Enthusiasts Forums
Dyno charts.
Old 07-09-2007, 09:48 PM
Xyzzy's Avatar
Xyzzy Xyzzy is offline
Xyzzy is starting off with a positive reputation.
Dyno charts.
I have searched and searched. I probably used the wrong search terms or something, but I have come up empty handed.
I'd like to see full dyno charts for current model 4.2, 4.6 and 5.4 engines.
I'm interested in the "official" charts (crank) and the real world charts (rear wheel).
None of my brochures have this info. They just list peak numbers which are worthless to me.
I'm looking for stock charts, nothing fancy.
Back in the day, when I was into motorcycles, a dyno chart was included in every magazine test. I'm new to trucks so I don't know what publications have these charts. You'd think Ford would publish them.
A Tundra catalog I got the other day (I have no idea how they got me on their mailing list, although I did have a Tercel like a billion years ago) has watered down (and suspiciously optimistic) dyno charts but at least they are somewhat useful.
Unrelated but worth asking: I've also been searching to see if the current 4.6 engines suffer from plug blow-out, plug seize-in or anything else out of the ordinary. I'm guessing (from looking at the spark plug part numbers) that the 4.6 does not use the same plugs as the 5.4 so that might eliminate the seize-in issues. I'm assuming, and hoping, the heads have more than a few spark plug threads, too.
Finally, the newest 4.6 (248@4750/294@4000) has almost the same power today as the 5.4 (260@4500/350@2500) did when it was first introduced. Obviously, the torque figures are not close and the 4.6 has to rev higher to make the power. Does a newer 4.6 feel anywhere close to a first generation 5.4 or does the extra ~50 cubes trump all no matter what? I'm guessing them 50 cubes matter a lot. 60ft-lb at 1500RPM lower has to be a big difference.
Okay, one last thing. The 4.6 (and 5.4, although not lately) seems to be on this list a lot:
http://en.wikipedia.org/wiki/Ward%27s_10_Best_Engines
Look at 2007, 2006 and 2005. Did the recent 5.4 spark plug problems contribute to the 5.4 falling off the list? At one time the 5.4 owned the list.
Thanks for any insight!
Old 07-10-2007, 03:52 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Look at K&N's website knfilters.com and Superchips' website Superchips.com. They have before and after dynos, mostly rear wheel.
Old 07-10-2007, 05:47 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Part of the problem with dyno charts:
Gear ratios, tire size, tire inflation, wheel size, 2x4 or 4x4 and bed length (which changes drive shaft length) all have an impact on dyno charts. Dyno charts are good for showing relative gain on one setup, but not for comparing absolutes for all setups.
Also, too many folks look mainly at the HP numbers... great if you like spinning your engine fast. What counts with these trucks is torque, especially on the low end.
Old 07-10-2007, 06:28 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Elevation also plays an important role as well as the ambient temperature.
As for the list I have seen it and think it is pointless, there is no reason the 4.6L should be on it and not the 5.4L or visa versa, when the 5.4L is just a stroked version of the 4.6L for all intents and purposes. I equate it to Consumer Reports giving a Mazda truck a much higher ranking than a Ranger when they are the exact same thing just with a little different front body panels. When I see things like that there is an obvious bias or just plain lack of intelligence.
Old 07-10-2007, 06:42 PM
FTE Ken's Avatar
Elevation, air temp and humidity all play a role. Dynos generally have sensors for these which is why we have graphs, and corrected graphs produced by the dyno.
Engine oil temp, engine temp, coolant temp, fuel temp and air intake track temp also are factors. One of the reasons people use fans on dynos to minimize heat soak.
Old 07-24-2007, 09:52 PM
1987 4x4's Avatar
1987 4x4 1987 4x4 is offline
1987 4x4 is starting off with a positive reputation.
air temp makes a big noticable difference for my 97 4.6 and my 04 5.4 they seem to make more torqe and more horsepower when it is cooler weather Ive noticed this driving them both to work the 5.4 is in a 04 f150 4x4 and i love my truck. the 4.6 is in a 97 mercury couger xr-7 30th anniversary that actually belongs to my wife but i drave it to work daily with a 35 mile one way drive this one is a little sluggish getting started but it get 24-25 mpg so im thinking that it is geared for highway driving and i would be a fool to change them since i have to drive that distance.
4.6 vs 5.4 Spark Plug Problems SC_Hoaty Modular V8 (4.6L, 5.4L) 10 12-12-2013 10:34 PM
Diagnostic trouble code chart for 2009 F250 w/5.4L GMT Modular V8 (4.6L, 5.4L) 0 05-13-2013 09:01 PM
Trans chart kedwinh Clutch, Transmission, Differential, Axle & Transfer Case 3 07-18-2011 11:43 PM
302 power curve chart Milwaukee1979F150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 12-20-2009 11:16 PM
Questions about 4.6 wa2be 2004 - 2008 F150 4 08-31-2009 10:55 PM
Tags
2006, 46l, 54, 54l, 67, 97, chart, charts, curve, dyno, f150, f250, ford, graph, numbers, stock, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
