Nitrous on order
Originally Posted by xtrm1stang
I just ordered all the parts for my nitrous kit, As soon as it gets here and installed I'll let ya know what a difference 100 hp does on a crew cab fx4. I'll even take it to the track and post before and after #'s. pics too.
Mr86GT
Originally Posted by Mr86GT
I'm not trying to be a wiseguy or anything...but...just a question...will the 5.4L SOHC Triton actually TAKE that kind of abuse?? I know the Mustang 5.4L blocks can, but they are built for such things, I don't think our trucks are. With all the problems we all have with cam phasers and such, is NOS such a good idea?? I'm even leery about ordering a Roush charger for my FX4. Just a question being thrown out there.
Mr86GT
Mr86GT
Originally Posted by tylus
unless you're talking about the GT 500, the Mustang comes with a 2v, 3v or 4v 4.6 V-8. The 5.4 is built more than strong enough for nitrous. Just make sure you get a good kit and run the motor with plenty of air. A lean motor with nitrous is a dead motor.
on
Mr86GT
Mr86GT
Are you installing a "wet" kit or a "dry" kit. The wet kit uses two solenoids. One for N20, and one for fuel. The dry kits rely on the 02 sensors and OEM injectors to keep the fuel mixture correct at WOT. If you are running a dry kit you may want to step up and install higher flow injectors, and maybe even a higher flow fuel pump. If it gets lean you will burn holes in the top of the pistons, quick!
NOS is perfectly safe if used properly. I've seen it successfully/safely used thousands of times, but also unsuccesssful quite a few times also. On a truck that's your driver, don't be weary of shutdown sensors that monitor fuel pressure and things like that, they'll help keep you from detonating(literally) your motor.
edub32
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
04-09-2005 05:33 AM
