Question for Phydeaux88
Enough heat from any source can cause polymerization to accelerate.
Not sure what effect the UV would have, I know that some research has shown that exposure to sunlight will cause BD to oxidize and polymerize at faster than normal rate.
I saw a paper that recommended storing in a glass lined metal tank with nitrogen in the head space, if long term storage is necessary.
Thanks Phydeaux for the info, been a little busy with harvest or I would of thanked you sooner..........This thread got a little more milage than I thought it would. Just trying to get as much info as possible about this new crop.If it will produce as good or better than canola, I will try some test plots.
Here is one of the studies I looked at that discusses Camelina
http://www.hort.purdue.edu/newcrop/p...93/v2-314.html
