Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-09-2007, 08:35 PM
tjbeggs's Avatar
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
Throttle pedal issue/TPS: Easy Fix!
I think this has been posted before but i have now experienced it and have pictures to help!
Ok so i bought a used throttle pedal assembly for a spare. I plugged in to check it and low and behold I had a CEL even when the key was just on let alone engine running. So I grabbed the scanner and had a P0122-AP Accelerator pedal sensor ckt low input
So I looked at the data and everything looked good but TPS voltage was low at .37 volts. Truck came off idle and it operator normally but still had that CEL. So I check the computer for diagnostic info. it said that anything at or under .37 volts will set the light. So I pulled the assembly back off and started to check it out. Well I foudn the bushing on the opposite side of the TPS was backed out and allowed the shaft to cock side ways under the spring pressure. So easy fix put the bushing back where it belongs. Voltage went to .51 volts and the code went away!
Here are some pictures to help you see the issue
http://good-times.webshots.com/album/559819076QNBcVu
__________________
Tim
Proud User of "The Cure"
1997 F-350 PSD Auto 257K
Tuned by Tony, Built by ME!
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
1/4 mile-14.59@88 MPH
Click the Picture for wiring diagrams, tech info and Pictures!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-09-2007, 09:55 PM
fast freddie is starting off with a positive reputation.
Good job Tim. I like a guy that drills on down to find stuff like that. Not many have the patience
  #3 (permalink)
Old 06-07-2008, 03:02 PM
250turbo is starting off with a positive reputation.
thanks tim. had cel, flashing od light & code po221.all good to go now
__________________
'96 f250 h.d. p.s.d. super cab,long bed,e40d with cOOnhunterjoe trans mod.gutted ebpv,3x4 d.p. & 4" exhaust,gauges,ab injectors,tranny& inter coolers,ex. brake,ccv mod,130 gallons motion lotion,fs2500 by pass,certifed j b welder
  #4 (permalink)
Old 06-09-2008, 03:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP is gaining momentum as a positive member of FTE.RÖENTGEEP is gaining momentum as a positive member of FTE.
Thumbs up
PSD Throttle Pedal problem pictures from friends & fun photos on webshots
Good work, reps sent. (at last).
__________________
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; shim FPR; tranny cooler; CCV mod; 4" stainless Magnaflow; SS 5" tip; no cat; RacerX VB; TW 6p chip.
«Primum non nosere»
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
