Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-09-2007, 07:13 PM
rolledranger is starting off with a positive reputation.
2.9 idles only
I'm helping a friend, he dropped an reman 2.9l in his ranger, he said it ran fine??
then shortly after he puked the tranny. now the truck only idles.kinda rough,
when you try to open the throttle in misses, back fires in the intake. and will only reach about 1500 rpms. if you feather the throttle you can get it to about 3200 but sounds like its missing a few cylinders. but as soon as you let off the throttle it drops back down to around 600 and sounds ok. swapted tps sensor, no help. i think it might be the EEC?? but not forsure. i'm a bowtie man chasing the oval looking for help. Any Ideas? or and Place I should start to elimate the basics?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-10-2007, 12:44 AM
mrshorty is starting off with a positive reputation.
1st thing I would do would be to pull codes from the computer. Put Ford EEC-IV self-test into your favorite search engine.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #3 (permalink)
Old 07-11-2007, 01:51 AM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
Hi and welcome to the site! As mrshorty said, check codes. You don't need a code scanner to do it, although that does make it a bit easier. Here's how:
http://fordfuelinjection.com/?p=13
And here's what the codes mean:
http://fordfuelinjection.com/?p=14
I would suspect low fuel pressure myself, so I would check that as well. A Ford EFI engine needs about 40 PSI to run properly, this one sort of sounds like it's starving.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
