Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-09-2007, 06:03 PM
carbonmetallic carbonmetallic is offline
carbonmetallic is starting off with a positive reputation.
Clay bar?
I have waxed every car i have owned and never used a clay bar or any type of polish and had the car shine really shine. Do you really need to use a clay bar and polish to get the new car shine?
How do you use the clay bar without scratching the paint?
  #2 (permalink)
Old 07-09-2007, 09:35 PM
Tim_Cannon Tim_Cannon is offline
Tim_Cannon is starting off with a positive reputation.
I use the clay from Griots, lubricated with Speed Shine .... spray on the SS, 2 foot area or so, go over it with the flattened clay bar, wipe with a clean polishing towel. Does a good job of removing things you can't see ... but if you run your hand across a before and after section you can really tell the difference.
  #3 (permalink)
Old 07-10-2007, 12:20 AM
Half Breed Half Breed is offline
Half Breed is gaining momentum as a positive member of FTE. Half Breed is gaining momentum as a positive member of FTE.
I use a Meguires Clay bar with the Maguiers lube. I was very skeptical before I used my first clay bar. If I had known the diff. it makes especially to the touch not to mention it seems to make it easier to wax and polish, I would have used one a lot sooner. I was blown away.
  #4 (permalink)
Old 07-10-2007, 09:07 PM
maevans's Avatar
maevans maevans is offline
<--Michigan GTG
maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE.
Quote:
Wash and dry your truck, Make sure you spray the area first with the spray included, ( no bigger than 2' x 2') Rub the area with the bar, then dry with a clean cotton towel. After about 5 to 6 hours your done. Then re-wash the truck. Time to wax.
I do mine once a year, Takes the hole day.
__________________
MARK
EARLY 99 PSD.
MICHIGAN CHAPTER
ROADSIDE HELP MEMBER
Pics and Mods in Gallery.
Have a Great day........
  #5 (permalink)
Old 07-12-2007, 05:27 PM
notasinger's Avatar
notasinger notasinger is offline
notasinger is starting off with a positive reputation.
I agree with all the above as far as application and results. I will never wax another vehicle without step two clay bar. I used the meg and it is very easy to do and well worth the time. Try it once and you will not go back to just waxing.
  #6 (permalink)
Old 07-13-2007, 08:23 AM
So I should wash, then clay bar, then wash, then wax. Wow that will take all day on my expedition. My wife's saab i could probably do pretty quick. I am assuming that doing this on a black metallic car would help get the swirls out?
  #7 (permalink)
Old 07-13-2007, 04:12 PM
notasinger's Avatar
Since you have swirls, I would recommend:
1. Wash
2. Clay
3. Polish (compound or swirl remover)
4. Wax
To take it a step further wax with a synthetic and come back 12-hours later with a carnuba (sp?) wax to seal. Do it right once and future applications will not take as long and you will be very pleased with the overall results.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
