transmission cooler lines run through radiator? - Ford Truck Enthusiasts Forums
Old 07-08-2007, 10:07 PM
yellow73bb yellow73bb is offline
yellow73bb is starting off with a positive reputation.
My 2000 F350 does not run the transmission cooler line through the radiator. Is that normal, or did someone put in the wrong radiator before I bought it? When I bought the truck, the lines ran only to the dedicated transmission cooler in front of the radiator, so I added a second cooler. Everything is fine until I am pulling a trailer loaded with toys up an incline at slower than normal speeds. I did this last week, gained about 4000 feet of altitude in 8 miles, dirt road, about 20 miles/hour, and my trans temps went over 250 deg. F. Normally, they don't go much over 190 on the highway.
Any thoughts/suggestions?
John.
Old 07-08-2007, 10:16 PM
Uzumati's Avatar
Uzumati Uzumati is offline
Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.
I think the OTW cooler started in 01
Old 07-08-2007, 10:52 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
250 degrees?? Hope you changed your fluid...
Old 07-08-2007, 10:56 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Replace your bypass valve.
It's a pattern failure on the automatics and it's cheap, like $40.00.
Too inexpensive of a part to overlook when trying to diagnose hot trannies.
Old 07-08-2007, 11:05 PM
John311t John311t is offline
John311t has a good reputation on FTE.John311t has a good reputation on FTE.
I thought the OTW was in 00?
Change your fluid soon, or youll be changing a transmission.
Old 07-08-2007, 11:06 PM
clux's Avatar
clux clux is offline
clux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputation
Quote:
The added the OTW cooler during the 2000 MY. Mine has the OWT cooler, March of 2000 build date.
Old 07-09-2007, 02:01 AM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
My 2000 has one too. I believe the 1999's are the only year NBS to not have them.
Pop
Old 07-09-2007, 04:18 AM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE.cangim is gaining momentum as a positive member of FTE.
I know for a fact my early 99 doesn't have one. yellow73bb, I'd opt for a puller or pusher fan for your auxillary cooler, summit has quite a few. OTW cooler would be nice but even in this situation you describe, 20mph - heavy tow - incline, I don't think the OTW cooler would be as beneficial as a good fan.
Old 07-09-2007, 09:39 AM
I'll drop the tranny pan, replace the filter and fluid, and replace the bypass valve. I'm not sure if there is room for a pusher fan there or not. I guess I could mount the aux. cooler somewhere else . . . . .
Old 07-09-2007, 10:17 AM
My late '99 with ZF-6 has one.
Old 07-09-2007, 01:08 PM
408w 408w is offline
408w is starting off with a positive reputation.
I have an 02 F250 7.3, is the small cooler located in the front of the A/C condensor the tranny cooler on mine? Or is in between the condensor and radiator?
Old 07-09-2007, 01:11 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
The small cooler is for your PS fluid. The cooler between A/C and Radiator is your tranny cooler.
Old 07-10-2007, 03:21 PM
Casey Casey is offline
Casey is gaining momentum as a positive member of FTE.
Quote:
Nope. Ford didn't start installing the radiator cooler until February, 2000, so there are a bunch of 2000 MY trucks out there without one.
Old 07-10-2007, 03:31 PM
Quote:
Good info to know!
Mine's an 05/00 truck, so I was lucky on this one.
Thanks for the additional.
Pop
Old 06-19-2010, 08:34 PM
Resurrecting this old post. Still overheating every summer. I put a new fan clutch on this last winter, I replaced the bypass valve last summer, I put in the highest capacity tranny cooler I could fit. Today it went up to 230 pulling up a hill.
I'm thinking I'll have a radiator shop put in a OTW radiator.
I had heard somewhere that a bad torque converter could cause the oil to overheat. Is there any truth to this? It locks just fine at highway speeds, so I'm not sure how it would fail.
Any ideas before I start sinking money into this thing?
Will another auxiliary cooler increase line pressure and slow the ATF flow? blanes Clutch, Transmission, Differential, Axle & Transfer Case 6 08-11-2014 12:16 PM
Radiator for Auto Trans BushyTea 1961 - 1966 F-100 & Larger F-Series Trucks 2 02-15-2014 06:26 PM
transmission cooler lines johaner78 1973 - 1979 F-100 & Larger F-Series Trucks 15 07-31-2012 07:37 PM
Why not unhook trans lines from radiator? whiteaddiction 1994.5 - 1997 7.3L Power Stroke Diesel 10 09-01-2009 10:28 PM
Factory cooler questions on 1989 F250 Fourwheelinj1 1987 - 1996 F150 & Larger F-Series Trucks 2 02-15-2007 11:30 AM
Tags
2000, 2001, 350, 73, change, cooler, coolers, diesel, f250, f350, ford, hose, lines, otw, radiator, stock, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
