Click!!
on
1 Post
Click!!
Very unusual happening. Drove truck all moring. Go to use it this afternoon, click. Jump solenoid, click. Tap on less than year old starter, click. Both batteries are less than 2 years old and read 12.5 volts. But one is only 65% and the othr 80%. Could that be the problem? I know from experience that 12.5 volts will not always crank an engine.
on
1 Post
I was already late, but when I went out to check it, 15.1 volts and fired right up. Drove it 50 miles with nothing on but the radio. Turned it off and tried to restart, same old click. Hooked the battery charger back up and put it on the start setting and it started right up again with little or no voltage drop on the meter. Moved the charger to the passenger side and it also read the same voltage as the driver side, 12.9, but after about 30 seconds it started to arc on the positive terminal. I got a proplem I have to find, but unless a magician here has the answer it will have to wait until tomorrow. Thanks for the help. I at least got to where I had to be and got home.
on
on
1 Post
A very little bit of acid corrosion on the passenger side positive terminal, none at all on the drivers. I have no baking soda and do not feel like going to get any today. That may be the problem? The cable is original, 196,700 but looks alright. I can't even tell where the damn thing comes from nor to where it goes. I suspect it is very important though.
Originally Posted by ron's power stoke
clean all post and cable ends...sounds like a bad conection..
A loose/flakey connection anywhere in the circuit will produce those symptoms.
Clean EVERY connection at both ends of the cable down to bright metal and take it from there.
Ive had corrosion on a terminal and just jiggled the wire & it would fire up fine for a couple days or more but eventually your problem will happen again. Plus it will keep eatin away at the connections or worse- Cause high amps under load . Just me , but id clean all asap like kwik said. Good Luck.
[QUOTE=guitarpicr]Ive had corrosion on a terminal and just jiggled the wire & it would fire up fine for a couple days or more but eventually your problem will happen again. Plus it will keep eatin away at the connections or worse- Cause high amps under load .QUOTE]
yep will eventually eat starter also
