Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-08-2007, 01:27 PM
78f150m is starting off with a positive reputation.
4x4 not working
I have a 1994 f150 the 4x4 stoped working the buttons dont light up when you push them do you thing the auto locking hubs could be messed up or a switch? Also how hard is it to change auto to manual locking hubs?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-09-2007, 06:54 PM
flcracker9 is starting off with a positive reputation.
Could be the hubs, or the electric shift motor. Have a friend put it in and out of 4wd (engine off, key on) while you sit underneath the truck. You should be able to hear the shift motor shift the transfer case in and out of gear. If you can hear that it's shifting, try putting it in 4wd and drive it forward, and have your friend look to see if the front driveshaft is turning. I believe those years had the hubs that worked by centrifugal force(?), so if the front driveshaft turns, but you don't have 4wd, it's probably the hubs?
__________________
74 F250 High Boy, 300ci, Demon 525, EFI maifolds, 260H Cam, 39.5 Swampers
86 F150 4X4, 351, GT40P Heads, 274 Cam, Crane roller rockers, Mac Headers, Demon 725, 35" pro comp muds
03 F250 Super Duty 7.3 Diesel, K&N Intake, Edge W/Attitude programmer, 4" exhaust, 35" Mickey Thompsons
  #3 (permalink)
Old 07-09-2007, 09:05 PM
kjett's Avatar
kjett has a great reputation on FTE.kjett has a great reputation on FTE.kjett has a great reputation on FTE.kjett has a great reputation on FTE.kjett has a great reputation on FTE.
Quote:
Give the procedure clcracker suggested about putting it in 4wd. Usually the motor will "freeze" up if you don't use it often, or if you get it wet/covered in mud often, heck just about anything will blow that shift motor out (ask me how I know and I'll show you a couple from my 95 mud truck....)
Switching ot manual hubs is a snap and is recommended if you take the truck off road often. Get the Warn hub kit that has the conversion parts and you will be all set. All you will need tool wise is some snap ring pliers, a set of picks, and some Allen wrenches, and you'll be done in about 20 minutes with a beer break in between!
__________________
Karl
I'm the Voice of Reason
FTE - Where signatures get edited with no explination why.
95 F-150
1995 F-150
Ranger build: Ranger Mud Truck
  #4 (permalink)
Old 07-10-2007, 12:29 AM
fishmanndotcom's Avatar
fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.
kick it!
-cutts-
__________________
Quote:
Originally Posted by Ingolf View Post
yeah, im a rich kid. but hey, i dont hate my parents for it. my dad drives a lambo.. so what the **** do i care LOL
  #5 (permalink)
Old 07-10-2007, 06:54 AM
KubotaOrange76's Avatar
KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.
get under the truck with a hammer and have someone hit the 4x4 button while you beat the motor with a hammer
__________________
2007 Dodge 3500 4x4 DRW G-56 5.9 QC 46,500k CM flatbed "miscellaneous efficiency mods"
1989 f-150 2wd xl lwb reg cab 300-6 2.73 195k..beat on every day!
Check out my gallery to see my old truggy.
  #6 (permalink)
Old 07-10-2007, 11:54 AM
75F350's Avatar
75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.
BFH! BFH! BFH!
Obviously Kubota and I have read the same manual.
Actually sounds like a switch problem. If the hubs were inop, the t-case would still engage. Since the case is not working, you may verify voltage through the switch.
  #7 (permalink)
Old 07-10-2007, 06:47 PM
then when you find the motor is sticking seriously try beating it with a hammer, if that dont work take it off and clean/lube it
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
