Erratic Idle:
Erratic Idle:
On my 239 flathead it will idle just fine then all a once the rpms will go up a couple of hundred and then it will idle back down to normal.I adjusted the idle mixture screws and seemed to help a lot,but still seems to do it every once and awhile.Any ideas on what else I should check?Thanks,Russell
on
Originally Posted by leonharu
What is an easy way to check for vacuum leak?
on
1 Post
Originally Posted by havi
starter fluid/ether.
Have you placed a vacuum guage on the truck to see if you are within the correct range?
You also indicate that you adjusted the Idle mix screw on the carb and it helped alot. Which way did you adjust leaner or richer?
The idle adjustments don't vary much from what I've seen. Turn them all the way in - careful to not crush the needles into the seats - then open 1 1/4 to 1 1/2 turns.
An old trick if you have junk in the carb orifices is to remove the air cleaner, rev it to between 1500 and 2K rpm and slap a piece of board on the carb top until it stalls. Tends to flood the passages and will often clear the crud. Course it's not recommended from a safety standpoint, but nothing that works is recommended these days..........
on
I adjusted in until truck ran rough and vacuum started dropping then I backed out about 1/4 turn on one screw.On the other screw it don't seem to effect the idle and the screw is ran just about all the way in.I don't understand this!
Just a quick note here:
While checking for vacuum leaks using starting fluid, carb cleaner, wd-40, or other flammable materials be a little careful that you don't have some bad plug wires. A misplaced spark can lead to some exciting times in the garage (I'd rather not go into the details on why I'm bringing this up.....eyebrows do grow back though)
Bobby
Bobby
on
1 Post
Originally Posted by GreatNorthWoods
If it's running okay with one idle screw all the way in and the other at only 1/4 turn my guess is that it's getting air from some place else (like the base gasket or some other place on the carburetor). Like Tim said the idle mixture screws should be open 1 1/4 to 1 1/2 turns...
