Blinking Overdrive light Help!!! - Ford Truck Enthusiasts Forums
Old 07-08-2007, 10:29 AM
fanurios fanurios is offline
fanurios is starting off with a positive reputation.
Exclamation Blinking Overdrive light Help!!!
I have a 1995 Ford Explorer xlt. Overdrive light has been blinking for sometime now. The car does not kick into overdrive and revs pretty high- BUT Once i let off the gas a bit and press back down on the accelerator - IT DOES KICK INTO OVERDRIVE!!
A few weeks ago I tried to get the codes pulled by Ford but they told me the computer was not communicating with their scanner tool(both style scanners they have). So I took the car back. Another mechanic told me that it was a bad solenoid. Instead of guessing which solenoid I purchased a valve body assembly for under $200(MSRP $800) which includes all the solenoids as a local Lincoln Mercury shop was going out of business. I dropped the pan- no metal shavings, normal color/smell to the oil. replaced the valve body and gaskets, checked all the wiring and ground straps- ok. Reset the Cpu and test drove the car- The car still has the same problem!!!
*Question is- since the car does kick into Overdrive when I release the pedal and then press back down could the problem be a faulty throttle position sensor??? Or any other ideas? Thanks, Chris
Old 07-09-2007, 11:16 AM
caseys's Avatar
caseys caseys is offline
caseys has a good reputation on FTE.caseys has a good reputation on FTE.
Old 07-09-2007, 12:55 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
The first thing I would do would be to get the trouble codes from the computer. The vast majority of '95's were EEC-IV/OBD-1, so you can likely get trouble codes with nothing fancier than a paper clip. not sure why Ford couldn't get trouble codes, is it possible they thought your '95 was OBD-2/EEC-V and were trying to get codes from the under dash OBD-2 connecter (which is almost always non-functional in '95's)? The EEC-IV self-test connectors are under the hood, driver's side.
Old 07-11-2007, 06:21 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
That happens to my 95 about every 6-9 months. Pulled codes, revealed nothing. Unhook the battery for 5 mins to reset the computer. If the light comes right back on, get it checked out. Also, it's not good to drive it with the OD light flashing as it's putting extra(cripple/limp mode) strain on the trans.
Old 07-11-2007, 11:23 PM
albung albung is offline
albung is starting off with a positive reputation.
try a new battery a girl i know had same problem batt died so it was changed and hasnt came back on yet
Old 07-12-2007, 11:23 AM
Thumbs up
Thanks for all your replies!!
MrShorty, you raised an Excellent point!!! The Ford Mechanic was trying to pull codes from the under dash OBD-2 connecter, which according to you is almost always non-functional in '95's. I did not nor did the mechanic know that the the EEC-IV self-test connectors are under the hood- driver's side!! I will take it back and educate him on where to pull the codes, rather than basically guessing what the trans problem is.
-chris
06 navigator overdrive blinking light BossTweed 1997-2006 Expedition & Navigator 3 07-02-2013 11:27 AM
2000 Explorer 5r55e transmission issues, drive and reverse. keiser Explorer, Sport Trac, Mountaineer & Aviator 7 05-23-2013 03:03 PM
1994 f-350 scanner hook up? e4od problems rangermann17 1987 - 1996 F150 & Larger F-Series Trucks 5 02-16-2009 07:00 AM
Need Some Serious Help With Tranny! fanurios Explorer, Sport Trac, Mountaineer & Aviator 1 07-03-2007 02:54 PM
General Transmission Question cnajp Aerostar 10 11-09-2004 11:45 PM
Tags
1995, explorer, flashing, ford, light, overdrive
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
