2006 F150 Keyless entry code
On a scab or a screw it is on the module behind the rear seat back mounted on the back wall of the cab.On a regular cab the module is in the side panel behind the drivers seat.
When you bought your truck they should have given you a card w/ the 5 digit code on it.However they didn't give me one for my 06.I guess they figured I didn't need it because my truck didn't have a keypad.I added new door handles with a keypad so I had to remove the rear seatback to get the code.
My F150 is a SCREW
So unfortunately it does look like I either have to tackle taking the rear seats out of a new truck or pay $40 to have the code read by Ford.
I do know a mechanic with a computer that would probably do it for free if his computer would do it. Does it have to be a FORD computer to get the code or would any mechanic that can read engine code be able to do this?
It is a factory keyless enrty code I am after. I have looked under the dash, nothing.
Yes, the Ford dealer has quoted $40 to do the code read. This truck is 9 months old and I am the 2nd owner, so the card in the owners manual was probably there for the 1st owner but you know how that goes.....Thanks to all hopefully this will all work out.
It's not too difficult to remove the seatback.I used the method used in the link below. Some people stick a screwdriver betwen the seat cushions and push on the clips to release them.I prefer the reach around method used in the link.
https://www.ford-trucks.com/article/...2006_F150.html
One dealer told me I couldn't and had to buy one of the new wireles that you stick on.
What did you have to do to install the keypad?
06 f150 Mark LT door Handles w/Keypad
[quote=NASSTY;4907001]The keypad on the door handle.My truck didn't come with the keypad so I got some Lincoln Mark LT door handles w/keypad on the drivers door.
Nassty,
The dealer told me I couldn't do what you have done. Something about replacing the security module for $600, reinstalling and programming( more $s).
They said I should buy one of the new wireless keypads to install for $130.
How did you install the door handles?
Did you run into any problems?
How did you activate the keypad?
Any guidance woudl be appreciated!
Nassty,
Vaughnr007 Send your VIN with a return e=mail address to https://www.ford-trucks.com/forums/s...ember&u=406391 FTE parts guy and ask nicely for a build sheet. If you explain what you are trying to do he can tell you if you can add the keypad as you want to. If you do need any parts talk to him about prices.
I'm not 100% on this myself. you guys do some mods that until I read it here I didn't even know it would work. I think if nassty chips in with a little more info getting the parts is not the issue, it's how did he get it to work, took it to dealer and have the module reprogramed? was the loom for the keypad there so all you had to do was plug it in? etc
Ed
Ed
Nassty,
I used this write up to install my handles. > http://www.f150online.com/forums/200...de-w-pics.html
