2006 F150 Keyless entry code - Page 2 - Ford Truck Enthusiasts Forums
Old 10-20-2008, 04:15 PM
glankerglanker glankerglanker is offline
glankerglanker is starting off with a positive reputation.
Quote:
Originally Posted by 06F150 View Post
It is a factory keyless enrty code I am after. I have looked under the dash, nothing.
Yes, the Ford dealer has quoted $40 to do the code read. This truck is 9 months old and I am the 2nd owner, so the card in the owners manual was probably there for the 1st owner but you know how that goes.....Thanks to all hopefully this will all work out.
I was in the same situation as you, I just pulled into the service bay at the local dealership and asked if they could look it up for me, 5 minutes later they gave got it from the computer(hooked up to my truck) and wrote it down for me and I was on my way free of charge.
Old 10-20-2008, 04:23 PM
FTE/PARTS-GUY FTE/PARTS-GUY is offline
Former Vendor
FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.
Quote:
Originally Posted by NASSTY View Post
Take the driverside door panel off to see if the plug for the keypad is there.If the plug is there it should be plug and play,as long as you know the 5 digit code.If you have an XLT the wiring should be there for a keypad.If you have an XL or a STX I can't say for sure?
thanks for the info.
ed
Old 10-20-2008, 09:33 PM
NASSTY's Avatar
NASSTY NASSTY is online now
NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.
Quote:
ed
No problem.Thanks for the help when I ordered my Mark LT handles from you about 2 years ago.
Old 10-21-2008, 11:08 AM
Former Vendor
sweet! I love it when it comes back around.
ed
Old 11-27-2009, 02:55 PM
chrowen chrowen is offline
chrowen is starting off with a positive reputation.
I found this thread searching for a way to find my code for my 2006 F150 FX4. After doing everything but removing the backseat, I called the original selling dealer of my truck. I politely explained who I bought the truck from and that they had lost the code. They asked for my VIN and within 2-3 seconds they gave me my keyless code. Much easier that removing that backseat...
Old 11-11-2010, 05:27 PM
joanbostic joanbostic is offline
joanbostic is starting off with a positive reputation.
06 F150 5 digit code for the keyless entry
The code for your 2006 F150 Super cab is located behind the rear seat. We just retrieved it for our 2006 pickup. It was difficult to get the seat out but if you read the following 2 threads and look and their pictures it helps. My hubby bent a rebar into an S shape and used that to reach behind the seat instead of his arm.
http://www.f150online.com/forums/2004-2008-f-150/377381-04-08-rear-seat-backrest-photos-back-side-back-rest.html
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
http://www.ford-trucks.com/article/i...2008_F150.html<o></o>
Old 12-21-2012, 01:24 PM
tbirdage tbirdage is offline
tbirdage is starting off with a positive reputation.
On a scab or a screw it is on the module behind the rear seat back mounted on the back wall of the cab.On a regular cab the module is in the side panel behind the drivers seat.
When you bought your truck they should have given you a card w/ the 5 digit code on it.However they didn't give me one for my 06.I guess they figured I didn't need it because my truck didn't have a keypad.I added new door handles with a keypad so I had to remove the rear seatback to get the code.
Spot on! Thanks! The module was exactly where you said it was on my buddy's regular cab. Thanks!
Old 12-25-2012, 10:24 AM
NASSTY's Avatar
Quote:
You're Welcome, thanks for the reps and Merry Christmas to you and yours.
Old 12-28-2012, 09:21 AM
dan150's Avatar
dan150 dan150 is offline
dan150 is starting off with a positive reputation.
I bought my 07 scab 2 months ago, didnt have the keyless code. Its behind the rear seat. Went on Utube watched the video on taking the seat out and me and my 15 yr old son had the seat out, replaced and keyless code set in about a 1/2 hour. piece of cake!
keyless entry factory code crozz 2004 - 2008 F150 3 09-26-2016 09:16 AM
keyless entry factory code crozz Iowa Chapter 0 09-25-2016 04:07 PM
computer module location/keyless entry code REDDOG_0_0_7 1999 to 2016 Super Duty 13 10-14-2013 10:45 AM
remote start with key-less entry question fordguy2236 1997 - 2003 F150 2 07-13-2013 10:49 PM
2000 f150 keyless entry wiring problem jeezjamie 1997 - 2003 F150 8 06-26-2012 08:00 AM
Tags
2004, 2006, card, code, computer, entry, f150, factory, fob, ford, fuse, key, keyless, location, module, reprogram
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
