K&N and Air mass sensor
>ok ive been reading about the K&N filter oil contaminating
>the air mass sensor...is this a very common problem and if
>so does it cause alot of damage or engine power loss?
Bear in mind this seems to be one of those self-perpetuating stories on the internet. There are likely dozens of readers here that have K&Ns with no problems. I've use a K&N on a MAF-equipped 460 for some time now with no contamination issues or visible dirt passing by it.
Now, if someone were to wash out their K&N and re-oil it sopping wet with oil, even the wrong kind of oil, yes, I could see where oil from it could and would get sucked into the intake system and MAF sensor. And there's no doubt that some meatheads have done exactly that, then blamed the "filter" for gunking things up.
That's my cut at it.
-Bill in Colorado
1996 Ex/Cab F-250 4x2 Long bed 460 E4OD auto, 10.25" 4.10 Stirling posi, Air-Lift suspension, homebrew cold-air intake w/K&N filter, modified ignition advance curve, Edelbrock 2x61 mm throttle body, Bosch Platinum +2 plugs, Champion truck plug wires, L&L long tube headers, 3" exhaust system, cat & Flowmaster 70, modified MAF meter, Michelin LTX 265/75/16E, Mobil 1 10W-30, Red Line D4 ATF, Red Line 80W-90 in axle. Reese hitch.
10 to 12.8 MPG, 5,700 lbs.
{E\...F}
-Bill in Colorado
{E\...F}
ssherron
12-14-2004 01:31 PM
