Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-06-2007, 11:10 PM
biltfordtough is starting off with a positive reputation.
Question Newbie - Steering Stabilizer Question
I know that this has probably been discussed before some where but I have dial up and my computer is way too slow to search everything that comes up. I was just wanting to know if I should or shouldn't invest in a steering stablizer for my truck. It is a stock 1990 f-150 4x4 with 33x12.50r15 tires on it right now. I have heard that if I put one on it will help so that the tires do not wear in a weird way, they will be pretty much even. Also heard that it will help with shaky steering. Any help would be really nice.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-07-2007, 12:31 AM
Ryan50hrl's Avatar
Ryan50hrl has a good reputation on FTE.Ryan50hrl has a good reputation on FTE.Ryan50hrl has a good reputation on FTE.
It never hurts to put one on....it will drive nicer
__________________
2007 Lariat screw - tri coat met - chrome package - Black leather captains chairs - sunroof - audiophile
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
  #3 (permalink)
Old 07-07-2007, 12:34 AM
79f150toy is gaining momentum as a positive member of FTE.
its an investment i would consider...just dont put like 4,8,10 of them on there, dual is usually ideal..but single would make a marked difference..
  #4 (permalink)
Old 07-07-2007, 01:09 AM
75F350's Avatar
75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.
If that thing steers funny or the wheel wobbles, you need to find the real problem. The steering stabilizer is only a band-aid to cover up porr steering performance. A system with all of the proper angles and tight components will not bumpsteer , and will not wear tires unevenly, nor will it allow the wheel to wiggle while you drive.
If you are installing shocks to look cool, then have at it, and more power to you, but if you are trying to correct a problem, then you need to find the root of the problem, and not cover the problem up. Failing to resolve any steering issues may result in an eventual steering component failure.
  #5 (permalink)
Old 07-07-2007, 02:50 PM
fishmanndotcom's Avatar
fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.
i could not have said it better myself! if you need a stabilizer you have bigger problems. and yes it can hurt. if you have a real problem and the stabiizer masks the wobble you could let it go months or even years before the problem becomes very serious and critical.
i have yanked stabilizers off every truck i have bought including any of my dads (even from the factory) and have never had an issue unless there was a real problem.
i'd say 99% of the stabilizers being used are for looks... and you certainly dont need duals like a lot of ppl think!
-cutts-
__________________
Quote:
Originally Posted by Ingolf View Post
yeah, im a rich kid. but hey, i dont hate my parents for it. my dad drives a lambo.. so what the **** do i care LOL
  #6 (permalink)
Old 07-07-2007, 02:59 PM
MBBFord's Avatar
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
Like 75F350 and fishmanndotcom said, it's a cover up.
My steering is a little loose, but everything up front seems to be fine(good and tight, nothing LOOKs wrong), so I put one, and it helped out, but I mostly put it b/c I didn't feel like spending hundreds to chase down the problem.
__________________
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #7 (permalink)
Old 07-07-2007, 03:21 PM
RawPower's Avatar
RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.
Quote:
Originally Posted by fishmanndotcom
and you certainly dont need duals like a lot of ppl think! -cutts-
Very few people need duals. If you are running 40+ inch tires and wheel it really hard, then it may be a good idea to help soften the abuse on your steering system, and your hands... but if you don't wheel much or run small tires, dual is really useless.
__________________
1993 F350 7.3 IDI, ZF S5-42, TS Div205, OEM/welded Rock's, 46's, 145" wheelbase
  #8 (permalink)
Old 07-07-2007, 09:27 PM
bla1879's Avatar
bla1879 is gaining momentum as a positive member of FTE.
my 6+ inch fabtech lift came with a single steering stabilizer, so i put it on, it drives nice, but idk what it would be like without it, so it could be its just another component they throw on to charge me more, or it could really work! the world may never know...
__________________
-- Brian --
'00 F-150 Triton 5.4L
Fabtech Lift
16" 51 series ProComp rims
315/75R16 Dunlop RMR
Spintech muffler
4.56 gears
Alpine iDA-X001
80 gig iPod Direct Connect
2 10" PBs woofers
2 5 1/4" PB mids
2 5x7" Clarion mids
2 1" PB tweeters
I CORINTHIANS 10:13
So-Cal Chapter Member
  #9 (permalink)
Old 07-07-2007, 09:49 PM
RawPower's Avatar
Quote:
Drive through a mudpit w/out it on... then with it on. The "whoops" and bumps throughout it will really take its toll on your fingers after a while...
Best solution to steering on a DD = hydraulic assist
__________________
  #10 (permalink)
Old 07-07-2007, 10:56 PM
bla1879's Avatar
im sorry, idk what a DD is, and whats a hydraulic assist? like a hydro ram on your steering?
__________________
-- Brian --
Fabtech Lift
Spintech muffler
4.56 gears
Alpine iDA-X001
2 10" PBs woofers
2 5 1/4" PB mids
2 5x7" Clarion mids
2 1" PB tweeters
I CORINTHIANS 10:13
  #11 (permalink)
Old 07-07-2007, 11:16 PM
RawPower's Avatar
a dd is a daily driver
hydraulic assisted steering is a street-legal modification that upgrades the strength of your steering set-up, and is ideal for larger tires... I was kinda joking when I suggested it though.
__________________
  #12 (permalink)
Old 07-08-2007, 05:42 PM
bla1879's Avatar
oh ok, see you learn something new everyday, so dont die in the morning!
__________________
-- Brian --
Fabtech Lift
Spintech muffler
4.56 gears
Alpine iDA-X001
2 10" PBs woofers
2 5 1/4" PB mids
2 5x7" Clarion mids
2 1" PB tweeters
I CORINTHIANS 10:13
  #13 (permalink)
Old 07-08-2007, 06:07 PM
RawPower's Avatar
haha never heard that before
__________________
  #14 (permalink)
Old 07-08-2007, 07:07 PM
STGFordCrazy04's Avatar
Dropped on Request
STGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to behold
Bla,
thats my new profile quote!
With my 79 F250 and 38" tires I can tell the difference for the better on bumpy roads and in mud. On the highway I dont think it makes a difference. It made the steering tighter and harder to turn on my 79 F150 4x4 with 33" tires so I took it off.
my .02
__________________
Kris
Quote:
Originally Posted by thorseshoeing
Yes you are the anti christ...
  #15 (permalink)
Old 07-08-2007, 08:29 PM
bla1879's Avatar
glad i could be of service to someone!!
__________________
-- Brian --
Fabtech Lift
Spintech muffler
4.56 gears
Alpine iDA-X001
2 10" PBs woofers
2 5 1/4" PB mids
2 5x7" Clarion mids
2 1" PB tweeters
I CORINTHIANS 10:13
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
