Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-06-2007, 06:01 PM
truszip is starting off with a positive reputation.
E-brake Question??
Okay - so I replaced all the brake components on the rear of my 97 F350. Hardest part was getting a replacement for the parking brake lever bolt. Of coarse no one had one? So I improvised by using a 1/4"x2" grade eight bolt. Seems to work just fine but now my problem is with the new shoes installed my parking brake goes' right to the floor and even then it's not holding?? With new shoe's would the parking brake need adjusting?? Doesn't make sense as I would think it should be the other way around in that in wouldn't take as much depressing to apply the brakes. Any advice or thoughts appreciated as I'm wondering if maybe I installed something incorrectly. Thanks.
__________________
1997 F350 4x4 PSD
2003 Escape Limited
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-09-2007, 07:07 PM
Big Blue 87 is starting off with a positive reputation.
Are the cables free to each wheel ? If one is frozen you will get nothing for a E-brake. The cables are not that expensive.
  #3 (permalink)
Old 07-19-2007, 11:19 PM
puddle jumper is starting off with a positive reputation.
A bad ebrake peddle assembly may be at falt.I you push on the peddel and the cable does not move its your problem.
  #4 (permalink)
Old 07-20-2007, 12:24 AM
PatsPOS is starting off with a positive reputation.
tru...something a lot of people overlook when changing brake shoes is adjusting the shoes out until they LIGHTLY drag on the brake drum. Just turn the star wheel up toward the bed with either a brake spoon or a wide common screwdriver.
If that isn't the problem, there's a lot of adjustment at the equalizer bar beside the left frame rail, too.
And, of course, you have a 10-year-old truck in a northern climate...as Big Blue said, it's not uncommon to have a rear e-brake cable that's seized in the sheath.
HTH...
Pat
__________________
'89 F-150 F14 4.9L (18.37 @ 73 MPH)
'91 Crown Vic P74 5.0L (18.09 @ 75 MPH)
'75 Gran Torino 7.5+L (14.04 @ 97 MPH)
Congressman Jack Murtha called me a racist and a redneck...jeez, tell me something I DON'T know!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
