You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I would pull tranny first. Too many people like to skip this step but it really becomes pain when reinstalling (and moving truck around). Also remove A/C condensor or at least put some heavy cardboard between it and the engine. The rest is like pulling any big block engine.
[updated:LAST EDITED ON 30-Jul-02 AT 08:56 AM (EST)]Pull the radiator and fan and the turbo. Disconnect the p.s.lines and A\C
lines. IF ITS A STICK YOU WILL HAVE TO PULL THE TRANS. I just had mine out in the spring to fix oil leaks and replace the clutch. Cherry picker handled it no problem. FYI the motor weighs 1010 pounds.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
1997 F350 PowerStroke 4X4,36 Inch Super Swampers, Strait Piped, Chiped, Propane Injected, LUK Clutch
