Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-06-2007, 11:01 AM
rswhitmore rswhitmore is offline
Garage is empty, add now
rswhitmore is starting off with a positive reputation.
Hoisting a Flathead V8
Can I pick up a flathead V8 with my engine hoist by removing the carb and bolting a lifting plate to the intake manifold?
  #2 (permalink)
Old 07-06-2007, 12:19 PM
dffay dffay is offline
dffay is starting off with a positive reputation.
I've seen that done a lot. Even from Aluminum manifolds. And I saw it done by Flathead Jack no less. He should know. It makes me nervous, but you can't argue with success.
The lifting was done to the engine alone, that is, not with a trannie or bellhousing connected.
  #3 (permalink)
Old 07-18-2007, 12:09 AM
4tl8ford's Avatar
4tl8ford 4tl8ford is online now
4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.
I prefer removing the intake manifild and uing a lifting plate, or if thats not possible I use one rear head bolt and an oppisite fron head bolt.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1952 Ford F2 (Non-Stock Flat 6)
1997 Ford Explorer
Every Thing I've Ever Said Is A Lie
  #4 (permalink)
Old 07-27-2007, 11:47 AM
I made a lifting plate out of 1/4 steel plate by using the intake manifold gasket as a pattern. I used forged eyes and a short length of chain for the lift part. It works extremely well.
  #5 (permalink)
Old 10-13-2007, 04:04 PM
mrcman58's Avatar
mrcman58 mrcman58 is offline
mrcman58 is starting off with a positive reputation.
Talking
I made a (remove the intake type) lifting plate from 1/4 in steel with a centered eye bolt, got the idea from Frank Otto's book on flatheads, it works great, also a great idea in there for a engine stand used by removing the exaust manifolds & bolting the stand on.
  #6 (permalink)
Old 10-14-2007, 09:47 AM
soule46 soule46 is offline
soule46 is starting off with a positive reputation.
Quote:
Is this the type that bolts only to one side of the engine? I have seen them for sale on ebay, but I have also seen a pair that allow you to mount the engine in the stand as though you bolted to the stand to the belhousing bolt holes. I just picked up a 59A and need to figure out a better way get it on the stand. I have a lighter duty stand, but it held up to the 8BA fine. I think my stand would do better rolling the engine as opposed to flipping it end to end. So I would be interested if anyone has made or knows where I can get info on the the pair that cradle the engine?
  #7 (permalink)
Old 10-14-2007, 12:27 PM
mrcman58's Avatar
Smile flathead stand
Hi Soule46,
i've seen the type you mentioned mounting to one side only, but the one i was mentioning is a 2 piece stand. I took a exaust manifold and traced it onto 1/4" in flat stock, i dont remember if it was 2" or 2 1/2" in wide, center punched the holes & drilled. and made a frame with 2in square tube. but the cross piece has 2 sizes of square 2" and another piece that fits inside of it, i have a nut welded to one side so once it is set up you tighten the bolt - and its sturdy. you can make it a stationary stand or put caster wheels on it. this should fit all the different flathead 8 models since the manifolds pretty much all have the same hole pattern. if you have access to frank otto's book on flatheads check it out, in the disassebbly & assembily section there is one being used, that is where i got the idea from.
Last edited by mrcman58; 10-14-2007 at 12:34 PM. Reason: forgot to mention something
  #8 (permalink)
Old 10-14-2007, 01:45 PM
mrcman58, I checked the catalogs of all the local libraries and only found Oddo's Street Rodder's Handbook. I assume you are referring to Ford Flathead V-8 Builder's Handbook 1932-1953. I have seen this book for sale as the "new edition" in paperback. Is this what you are referring to? If so maybe I will need to buy one.
Do you have any pictures of your's in use? Thanks.
  #9 (permalink)
Old 10-14-2007, 02:37 PM
mrcman58's Avatar
Talking
soule46, yes flathead V8 builders handbook 1932-53 is the title of the book, in my first post i couldnt remember it's title, & the book was out in the barn. i have an 8BA sitting on it now but it is sort of surrounded by junk - OH i mean Parts, might be hard to get a decent photo of it as it sits without 1/2 hour of pulling stuff away from it.
  #10 (permalink)
Old 10-14-2007, 04:10 PM
Overkill-F1's Avatar
Overkill-F1 Overkill-F1 is offline
Overkill-F1 is starting off with a positive reputation.
Click the image to open in full size.
I welded a length of angle iron to a piece of pipe at an angle, it bolts to the manifold bolt holes on either side of the flathead block.
I doubled the thickness at each end (Overkill?!).
Works great.
...Terry
__________________
It is a simple task to make things complex,
but a complex task to make them simple.
  #11 (permalink)
Old 10-18-2007, 09:45 PM
rcav8or's Avatar
rcav8or rcav8or is offline
If you use it, SUPPORT IT
rcav8or is starting off with a positive reputation.
Quote:
One thing I learned long ago, when you are going to put the engine on the stand, take the piece that mounts the stand to the engine, off the stand, mount it to the engine first, then lift the mount and engine to the stand. I still have seen a LOT of people over the years, try to mount the engine to the stand mount, hanging free from the hoist. For what it's worth...
I made two flat steel pieces that mount to the middle exhaust outlet bolts. Angled back the balance was just right. You can see them at:
My Truck 1
My Truck 2
One of those should work...
R
__________________
Roger Phillips
Oxford, IN
Click the link for pictures of my truck:
1951 Ford F2
Tags
193253, 59a, bellhousing, builders, engine, flathead, ford, handbook, intake, lifting, motor, pa, pattern, stand, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
