200 CID six/226 Flathead Compatability
at the bare minimum you'll need a universal V8 front mount bar for putting a 302 into a pre-64 ford pickup (transdapt 4849 should be close to what you need). Mount it farther forward then the V8 would need and weld atatchment points for 200 motor mounts on it. To mate the 200 bell to the existing transmission you'll need an adapter plate to go from a 65-up ford engine to a 49-64 ford transmission (I think its a transdapt TD0009). if the flatheads transmission is an early model (pre-49) your most likely SOL and will need to swap transmissions too.
4tl8ford
20
01-30-2014 10:36 AM
jmadsen
12-27-2011 03:16 AM
jaymontana
1947 and Older Ford Trucks
12-18-2007 03:03 PM
two stars
02-25-2006 06:14 PM
