fuel relay--how to get power to?
If you put a carb on a ranger that was fuel injected you don't want to run the electric fuel pump carbs are made to handle about 5 -7 lbs of fuel pressure the electric will make between 40-60 psi. The needle and seat on a carb won't hold that kinda of pressure. you will have to go with either a mechanical pump or a low pressure electric or you might be able to find a regulator for the factory pump.
jumbofordman
02-02-2015 05:15 PM
jasonmoss
1983 - 2012 Ranger & B-Series
12-21-2004 08:13 PM
FireMarshal3311
08-31-2004 08:31 AM
