Oil leak at dipstick tube flange fixed -with pics! - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 03-18-2010, 07:21 PM
countrycar's Avatar
countrycar countrycar is offline
countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.
3 things I found out when I did mine Glen.
1. Always replace the nut with a new one, it made things easier. The dealerships have these too. The knew nut snugged up real nice. I did as most of us have done, when I saw mine leaking, I tried to tighten the nut and stripped it. It's very easy to do.
2.Keep the O-ring oil free. It will swell up and make the install impossible.
3. When I did mine, it leaked slightly upon initial start up. I knew the seal would swell up when the oil hit it, and it did and the leak stopped.
It was only a small leak though.
I did it twice, because the seal got oil soaked on me the first time and I couldn't get it seat properly. Hope this helps yah out.
  #62
Old 03-18-2010, 09:34 PM
Billyclub's Avatar
Billyclub Billyclub is offline
Billyclub is starting off with a positive reputation.
I'm going to take it apart tomorrow. I am going to go to NAPA and see if they have a better o-ring, worth a try. I did install a new nut, the old one was bent on one edge so I had to throw it away. I think alls I did was overtighten the nut and it distorted to o-ring. Kind of hard to experiment with the tightness cause you have to remove the starter every time. This is still better than taking it to a repair shop, I learn alot when I get into the mechanics of the truck. before I discovered this website I would never have thought about doing this repair.
  #63
Old 03-19-2010, 10:42 AM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Finally repaired mine two weeks ago with the International Kit mentioned above. Thanks for all the tips and instructions! The 1/2" galley brush worked like a charm......not a bad job at all, just a little nervous about the flange falling in but after starting the procedure it wasn't a concern since the brush held it in place without a problem.
  #64
Old 03-20-2010, 08:49 PM
ztodd377's Avatar
ztodd377 ztodd377 is offline
of FTE, RHN, and BEER!
ztodd377 is gaining momentum as a positive member of FTE.ztodd377 is gaining momentum as a positive member of FTE.
Called the stealership about the parts (inner flange o-ring, new flange nut, and dipstick o-ring) and they said there was also an inner nut and that all those parts would cost me $68. WTF? $68 for 2 o-rings and a flange nut? Oh yeah, they said they're special order only too. Thoughts?
  #65
Old 03-20-2010, 10:36 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Get a repair kit from INTL as mentioned in post just above your's.
  #66
Old 03-20-2010, 11:50 PM
billcollector billcollector is offline
billcollector is starting off with a positive reputation.
while trying to loosen the valve cover bolt that the dipstick tube attaches to i managed to bend up my tube, and pulled it out of the flange.
does the tube just push back in that hole? it looks like it is flared on the end
  #67
Old 03-21-2010, 08:45 AM
Billyclub's Avatar
Quote:
The local dealershiphere charged $23 for the same parts ( Flange nut, inner o-ring and tube o-ring). If you want I can get the parts for you and ship them to you. I would call ED the parts guy on this forum, he would most likely beat everybodys prices. www.partsguyed.com
Billcollector- The dipstick tube just pushes back into the flange, you will feel the o-ring slip into the slot in the flange.
I had to take the whole thing apart a second time. turns out the first time I did the fix the flange o-ring was not in the groove that is machined on the piece in the inside of the pan. Taking it apart the second time only took about 45 minutes from start to finish. The .40 cal bore cleaning brush works really slick.
  #68
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Yes, the tube pushes into the hole.
Seals with an o-ring around the shoulder of the tube.
  #69
Old 03-21-2010, 09:13 PM
countrycar's Avatar
Bump.......
  #70
Old 03-21-2010, 09:23 PM
countrycar's Avatar
Billcollector, try not to bend the dipstick side to side. You'll know, if the dipstick is very hard to insert or remove and has alot of drag, then the tube is bent side to side. It should site straight from top to bottom. You might even have to remove it and lay it down flat and get any side to side bends out of it. It has factory contour bends in it, but not from side to side. Hope this helps yah out. Take care now.
  #71
Old 04-07-2010, 02:41 PM
ztodd377's Avatar
Does the gasket in that kit replace the oring on the inside of the pan? Or does it just sit on the outside of the pan under the flange nut?
Quote:
Originally Posted by Fat Diesel View Post
Hey guys,
I recently started leaking massive amounts of oil from the flange that holds the dipstick tube to the pan. As you may be aware, the flange is inserted from the inside along with the oring to seal it. I think it might be possible to replace that oring, but I went with the tried and true International repair kit.
Intl # 1846146C91 consists of:
Gasket
Oring (small one for the dipstick tube where it slides in the flange)
RTC
Loctite Flange Sealer
Instruction Sheet
Here's the gasket dimensionally if you need to make one in a pinch. 2 1/2" OD, 1 5/8" ID, and 0.031" thick.
Here is the RTV and Loctite flange sealer.
I started by disconnecting the batteries and removing the starter to gain access.
I then removed the bolt securing the dipstick tube at the top and un-hooked the wire harness and a couple of electrical connectors.
Next I cleaned up the flange and surrounding area.
The trickiest part of the whole operation is making sure that the flange does not fall into the pan while you take the retaining nut off and further clean and apply sealant. The directions called for a gallery brush (long straight round wire brush) but I didn't have one so I made a tool that worked sweet.
My custom tool was a piece of round plastic bar that was just under the size I needed it to be to wedge it in the hole that the dipstick tube sticks in. I ended up running a die over it to make some threads that increased the diameter of the plastic just enough to get a nice soft press fit.
I then drilled a hole and safety wired it to a carabiner so I could hook it to something and not have the flange fall into the abyss.
Here is the tool "installed."
Now comes the pucker factor 9.9 as you actually push the flange into the pan to remove the OEM oring with a pick like instrument.
Then I cleaned up both threads as best I could using brake cleaner, which by the way is a great way to get the clear coat off the pan... Then you use the RTV to seal two little slots on the pan and one "key" on the flange as you pull the flange back to it's seating position.
At that point I used the Loctite flange sealer to goop up the threads of both the flange and nut as well as both sides of the gasket. It is pretty messy sliding a gooped up gasket over the home-made tool but I got 'er done.
Now don't snicker too much on the sight of this ugly duckling, because the final words on the instructions were to use the RTV to COVER COMPLETELY the area around the slots and key. The key is there to properly position the flange so the dipstick tube is aligned.
Interestingly, due somewhat to the 105* temp outside, I could see massive outgassing from the RTV. Pretty cool to watch. Kind of like smoke pouring out of the entire surface area.
So far no leaks after 20 miles of driving!
Andy
  #72
Old 04-07-2010, 06:01 PM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
It will be installed on the outside...Many here(including myself)have changed the inner oring successfully and then you do not need the kit or have that glob of stuff on the outside.I would recommend buying a new nut and dipstick oring.Use a 45 cal bore brush to hold the inner flange while you remove the nut and inner oring.Get a partner to help or have everything laying where you can reach it.
  #73
Old 04-07-2010, 06:10 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
Here are the Ford part #'s:
inner oring...F4TZ6753A
dip stick oring...3C3Z6753AA
flange nut...F4TZ6751A
I found them on this thread: http://www.ford-trucks.com/forums/89...g-changed.html
I found them all on Ed's site for under $20 bucks.
  #74
Old 04-07-2010, 06:19 PM
Billyclub's Avatar
Check your local ford dealer you may not have to pay for shipping if the local price is reasonable.
  #75
Old 04-07-2010, 08:27 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
fixed the part numbers.
when entering part numbers into my site, all caps and no dashes.
test johnchesley Testing..... 2 02-15-2013 12:06 PM
2010 Daytona Turkey Run Photos GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 12-04-2010 09:27 PM
Dirt Devil 2.0 Dave Sponaugle West Virginia Chapter 19 03-28-2010 06:01 PM
Indiana truck pics cowmilker08 Indiana Chapter 2 04-14-2009 03:56 PM
Pics of progress AF Mezkin 1997-2006 Expedition & Navigator 11 01-14-2006 10:56 AM
Tags
1999, 73, diesel, dipstick, f250, fix, ford, leak, leaks, oil, powerstroke, rendezvous, replacement, tube, tubes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
