Oil leak at dipstick tube flange fixed -with pics!
#46
All you need is an appropriate size round brush like they use to clean engine oil galleys out. Push it into the dipstick tube hole and tie brush handle off to something, then remove nut and proceed with repair. After repair, replace nut and tighten, fan clutch wrench fits nut, pull out brush and finish the job.
Reps sent.
#48
Thanks! I shouldn't take credit for the brush idea though as when you buy Internationals repair kit for the dipstick tube adaper leak, its instructions detail the use of an engine oil galley brush to keep the adapter from falling in the pan.
#49
#50
I am quite certain a magnet would do you no good as the adapter is made of a non magnetic material.
#52
Hey everyone, I was replacing the glow plugs on my '96 that i just bought and loosened the bracket for the dipstick tube from the valve covers. When i slightly moved the dipstick tube i heard a clunk... yes that very same clunk everyone fears when replacing the gasket on the dipstick flange. I guess the nut became loose at some point and with the movement of the dipstick it just dropped the flange into the pan. Any ideas of how to fish it out without pulling the motor if a magnet will not work? Thanks for any suggestions
#53
Ok guys. So I never received a reply on my previous post but I decided to try to fish out the flange that dropped to the bottom of the pan. I purchased a Milwaukee video scope on craigslist, tapped a craftsman claw tool to it and gave myself plenty of time to search around. After about 4 hrs. of probing around and grabbing the flange at different positions, I was able to slide it up and through the whole in the baffle and up to its proper position on the side of the pan. Just wanted to let you all know, no matter how puckered you get when replacing the o-ring on the flange, if you happen to drop it, there is a way to fish it out. I would still worry though, it was a pain in the butt.
#56
It took me about an hour just to finally see it. Then another 3 or so hours of lightly twisting it or nudging to to grab it just the right way to slide it out the baffle. Once I finally saw it i wasnt nervous anymore because i didnt care how long it would take... it was coming out without pulling the motor! But yes i was sweatin a good bit
#60
I just finshed mine up this morning. Went and picked up my son at school. When I got back I peered under my truck to see oil on the driveway. Everything went together nice and I thought I didn't over tighten the nut but now I'm wondering if I over did it and squished out the o-ring. Coming out at the bottom and not the dipstick tube. To my way of thinking there is only one thing that could go wrong and thats the big O-ring on the inside wqs distorted by over tightening and was pushed out thus creating a channel for the oil to leak out.
Any thoughts if you do't think thats what happened.
Glenn
Glenn
