Oil leak at dipstick tube flange fixed -with pics! - Page 3 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 12-02-2009, 10:54 AM
gymnastically gymnastically is offline
gymnastically is starting off with a positive reputation.
do you have to drain the oil for this repair or is it above the oil level??
thanks!
-dave
  #32
Old 12-02-2009, 10:56 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Barry,
After 10k miles so far so good for me. No leak at the flange.
When I pulled the dipstick tube the o-ring was GONE.
That 0-ring is quite different. I bought an OEM because I had nothing to look at and after seeing the Ford o-ring I knew I couldn't find one like it at the parts store.
  #33
Old 12-02-2009, 11:17 AM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Thanks for the help guys, I just spent a quick 30 minutes under the truck in the daylight and waiting for the temp to get above 25F. My flange nut was a good 1/2 turn loose and I can can see oil goop climbing up the dipstick tube also. So like suggested I will go ahead and change them all while down there. With this being my first winter in South Dakota I don't want to be stuck out in the cold somewhere.
Seems like I got an early Christmas present from the diesel gremlins this year. I took a quick look in the engine valley to make sure everything else looked OK and now it seems I have a fuel leak from the fuel drain valve. Looks like the O-ring gremlins got me good this time.
Thank you again for you help & quick responses. I have only been on the forum a few times the past 5 months. The move to SD, work & kids school has my time strapped lately. It's cool that you are still willing to help someone that has been a ghost lately.....
reps to ya.....
  #34
Old 12-02-2009, 11:36 AM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
Quote:
thanks!
-dave
No...I did not drain the pan.
  #35
Old 12-02-2009, 11:37 AM
riverrat41's Avatar
Quote:
Originally Posted by PaysonPSD View Post
Barry,
It is a different looking o-ring.That is why I called it double beveled.That is what it looked like to me and I deal with many types.
Glad it is still dry.I hope it stays that way for ya!
  #36
Old 12-02-2009, 11:44 AM
riverrat41's Avatar
reps to ya.....
As far as I am concerned,once you are in the brotherhood here you are in.Everybody has time restraints and that cannot be helped.I am not nowhere near the most knowledgable here but when I can help I will help whomever because I have been helped plenty on here.
Guzzle will have those o-rings or you can get them and the dipstick o-rings from Ford.Do not tighten the nut too much and mash your new o-ring.You can do it,just think it through and take your time.
  #37
Old 12-02-2009, 01:06 PM
PaysonPSD's Avatar
When I thought I was going to have to replace the flange o-ring I made this widget to keep the flange from falling into the pan. Just to be safe and to help reduce the "pucker factor" (I was paranoid about this repair). Fortunately I didn't have to use it so it is untried but I sure think it would work. If I ever do need it I will make it a bit shorter and try to remember to put the o-ring and gasket over the strings before I tie it off and start loosening the flange nut.
  #38
Old 12-03-2009, 12:06 PM
Nice super widget Robin,
very nice.......
  #39
Old 12-03-2009, 12:33 PM
PaysonPSD's Avatar
very nice.......
Thanks Rich. Kind of a peace of mind thing plus you have both hands free to manipulate the flange without fear of it falling into the pan.
  #40
Old 01-04-2010, 04:47 PM
smojmokel smojmokel is offline
smojmokel is starting off with a positive reputation.
OK I now have the oil leak! My issue is that the nut is all the way off and can't get it started again? I took off the starter and was able to get my needle nose vise grips on it but I still can't seem to get enough threads to get the nut back on. Any suggestions?
Thanks Steve
  #41
Old 01-04-2010, 07:39 PM
riverrat41's Avatar
Welcome to FTE Steve....I bought a new nut because some here said they are cheesy.Maybe secure the flange and buy a new nut from Ford.They are not expensive.....Not sure what else besides take your time and try to get it started which you have probably already done.
  #42
Old 01-04-2010, 08:55 PM
rtazz17's Avatar
rtazz17 rtazz17 is offline
rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.
Quote:
Thanks Steve
Get a new nut.. Its probably cross threaded.. They are a soft metal.. Better that to cross thread than the flange... I did this job twice because I didnt get a new nut the first time.. The nut was cross threaded and I couldnt get it tight enough and had to do it again.. Not something you want to do twice.. Good luck
  #43
Old 01-07-2010, 12:06 PM
Thanks, That's what I thought too. I am going to make ,"THE SUPER WIDGET" so I don't hear the dreaded "clunk" I sure hope it works. I"ll let you know when I get a chance to get the parts and give it a try. I am working nights and about to start a remodel on the house, something will have to wait and it looks like the truck
  #44
Old 01-07-2010, 02:30 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Mine is starting to get real bad But I am so scared to hear the "Clunk" of death.
  #45
Old 01-07-2010, 02:54 PM
origcharger origcharger is offline
origcharger has a good reputation on FTE.origcharger has a good reputation on FTE.
All you need is an appropriate size round brush like they use to clean engine oil galleys out. Push it into the dipstick tube hole and tie brush handle off to something, then remove nut and proceed with repair. After repair, replace nut and tighten, fan clutch wrench fits nut, pull out brush and finish the job.
test johnchesley Testing..... 2 02-15-2013 12:06 PM
picture test harrisford User Gallery & Picture Display 3 07-16-2011 09:09 PM
2010 Daytona Turkey Run Photos GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 12-04-2010 09:27 PM
Dirt Devil 2.0 Dave Sponaugle West Virginia Chapter 19 03-28-2010 06:01 PM
Pics of progress AF Mezkin 1997-2006 Expedition & Navigator 11 01-14-2006 10:56 AM
Tags
1999, 73, diesel, dipstick, f250, fix, ford, leak, leaks, oil, powerstroke, rendezvous, replacement, tube, tubes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
