Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-21-2009, 05:15 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
Quote:
Originally Posted by Fat Diesel View Post
Naw. Just for barking orders while I kick it in the chair sippin' my beer! You live near Monterey or further south?
Seaside.
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #17 (permalink)
Old 11-16-2009, 06:59 PM
blueox9771 blueox9771 is offline
blueox9771 is starting off with a positive reputation.
I currently own a 7.3 that i had the same problem out of, but didnt have the luck you did with, changing every thing from the out side, i am currently going to school for Caterpillar, so luckily it messed up on me at the schools shop, tried the trick of holding the inter threaded piece and was shooting for an easy fix needless to say, it wasnt long after that i heard the "ca- flop" of the threaded peice hittin the bottom of the oil pan. good lord i about had to go to revival after that. so now i guess my only option is to pull the pan, and from what i hear that is one pain in the A$$. if you know is it possible to remove the motor and trans mount bolts and jack up engine with out removing the turbo,intercooler pipes, exhaust etc? please reply im in deep need of a easy fix. i gotta make it back home for thanksgiving.
  #18 (permalink)
Old 11-16-2009, 08:29 PM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is gaining momentum as a positive member of FTE. riverrat41 is gaining momentum as a positive member of FTE.
Welcome to FTE...It can happen to anybody because that is a very tricky job.I have changed the inner oring successfully but I had two safeties on it JIC.
I have read about loosening the motor mounts and jacking up the motor.Have not done it yet but some have here.They will have more advise shortly.We will get ya fixed up here.
__________________
Barry.....FISH HUNTER!
Tony Wildman Chip , 4''Exhaust, 6637w/Pete's Cover, Crossover, AIH Delete, Foil Delete, WW, Ped Gutted, Tugger Kit, Isspro Gauges, CCV, Recon smoke cab lights, Camo seat covers, Replacement Bumpers, Hutch/Harpoon ,Cold A/C Mod, True Cool
  #19 (permalink)
Old 11-16-2009, 08:39 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Quote:
Welcome to FTE. The oil pan won't come off without pulling the motor. You can jack the motor a couple of inches if you disconnect the mounts without pulling the turbo, but the pan gasket is RTV, so you're stuck with scraping and trying to clean things up so you can put the new RTV on for the re-install.
Do you have one of those snake cameras at the CAT shop? I've read where someone just drained the oil and used one of those snake cameras and a coat hanger or some type of stiff wire to go fishing.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #20 (permalink)
Old 11-16-2009, 08:43 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is online now
Caution! Will Blow Smoke.
Bigcat350 is gaining momentum as a positive member of FTE. Bigcat350 is gaining momentum as a positive member of FTE.
I have heard of this happening and they fished it back up to the hole. I think they used a cut coat hanger and a lot of luck but it can be done. There is a thread on here about how he did it. I seen it when I was looking for how to fix mine.
__________________
Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Ceramic/Kevlar Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
  #21 (permalink)
Old 11-17-2009, 09:49 AM
im probably going to just pull the turbo and intercooler pipes and oil pan its got 210k miles on it but dont want to have to go back and do this job over, or worst case it go to leaking agian when im not around some where conveient to fix it. when it started leaking i was on my way back to school and i had to put 10qts of oil in it just to get it back on the dipstick. but thanks for the help. i was trying to add a couple picture of my truck but when i click on insert picture it ask for the URL link. i've always had to browse to upload or insert a picture, can some one help me out on this.
  #22 (permalink)
Old 11-17-2009, 09:58 AM
rtazz17's Avatar
rtazz17 rtazz17 is offline
2002 Ford F-350
rtazz17 is starting off with a positive reputation.
When I was researching on fixing my own I came across a thread that showed a picture of this guys oil pan where he cut a small square in it and then welded it back because he dropped the flange in the abyss... Not recommending it , but its been done...
__________________
Rob-2002 f350 crew cab w/82000 miles..4 inch mbrp xl series stainless steel exhaust,S & B cold air intake,bilstein shocks,skyjacker dual stabilizer,285/75/16 firestone destination a/t,2.5 inch hanger/shackle leveling kit,disellite a/c cold mod.,back up camera,Pillar isspro guages pyro,tranny,boost,OBA, DP Tuner(80E no codes,no start,drive thru),foil delete,CCV mod,JW valve body,wicked wheel,08 aluminum rear diff cover coming soon and then who knows but something!!!
Tags
1999 , 73 , diesel , dipstick , f250 , fix , ford , leak , leaks , oil , powerstroke , rendezvous , replacement , tube , tubes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
