Oil leak at dipstick tube flange fixed -with pics! - Page 11 - Ford Truck Enthusiasts Forums
  #151
Old 03-04-2014, 05:34 PM
devonhubb devonhubb is offline
devonhubb is starting off with a positive reputation.
That inner o-ring can be a bear. Tip - if you have less threads showing at the top of the flange nut than the bottom, the o-ring has fallen out of the groove.
I wound up smearing the o-ring with vaseline. The vaseline made it sticky enough to adhere to the groove for reassembly.
  #152
Old 10-30-2014, 03:44 PM
Powerstoke73 Powerstoke73 is offline
Powerstoke73 is starting off with a positive reputation.
Quote:
Originally Posted by zukidave View Post
I was nervous about this repair. I have read all about it, I read this whole thread and more. It sounded harder than it was!
I got the dipstick tube O-ring, dipstick tube adapter O-ring, and new flange nut from the local Ford Dealer (what a rip-off at $47). Then last Sunday I went and got some needle nose Vise Grips and made a Widget. I disconnected the batteries and took off the starter. Then took the dipstick tube and flange nut off, removed the old O-ring's from the tube and adapter. Cleaned things up with rag and Q-tips. Put every thing back together using the new parts and using a little Loctite on the threads.
I figured the original O-ring's lasted 16 years and 280000 miles, I was happy with that! And If a second set of original type O-rings lasted that long I would be doing good. If not, It will be easier to repair a second time if it wasn't all gooped up with sealers.
After repair, I started the engine. About 10 minutes later I was disappointed to see a drip of oil on the flange nut. I carefully tightened the flange nut as much as I dared.
On Monday morning, after my 30+ mile drive to work, I was very disappointed to see oil all over the bottom of the truck. I was not looking forward to trying this repair again! After the drive home, the oil mess didn't look much worse. It seemed the leak had sealed some. So I hosed the oil off. Tuesday morning after driving to work, there was just a little oil that ran from the flange nut to the bottom of the oil pan. I hosed it off and it has not leaked since.
While making the repair, I did notice that the O-ring didn't protrude very much from the grove in the adapter. As mentioned in earlier posts, the O-ring swells in oil. I think the O-ring is designed to easily fit in the adaptor grove for ease of assembly, then swell to tightly fill the grove and mating surface sealing the assembly.
The moral to this story is; I don't believe the extra seal and RTV gooped all over are necessary. And if it leaks a little after repair, DO NOT PANNIC!!! It will probably seal after a day or two of driving.
IMHO This is an easy repair. Be prepared, but don't over think it.
Was it a constant leak that you could see right away or was it more of a seaping kind of leak
Thanks for the all the helpful information
  #153
Old 05-16-2015, 11:55 PM
sds5591 sds5591 is offline
sds5591 is starting off with a positive reputation.
Quote:
Originally Posted by rtazz17 View Post
I did this repair except I replaced with the stock o ring that sits on the inside of the pan on the flange...Did it in 1 hour and it looks great(no leaks and none of that mess on the outside}If you need help pm me and I can tell you exactly how I did it without dropping flange into pan....3.27 for the o-ring from ford and 1 hour to do...
RTAZZ,
Can you send instructions on how you replaced your dip stick o-ring in 1 hour ?
Thanks,
sds
  #154
Old 11-29-2015, 05:33 PM
Finality Finality is offline
Finality is starting off with a positive reputation.
From the research I have done, it should not be a big deal in the pan. There are kits that say it will fall in the pan and that it is not a big deal. I would want it out, but it sounds like it will not be a catastrophic failure if it stays in there for a while.
  #155
Old 02-07-2016, 05:57 AM
w9sig w9sig is offline
w9sig is starting off with a positive reputation.
I need help. We went to do this change yesterday. But we cannot get the dipstick tube out of the flange. Yes we undid the bolt to the valve cover. We pulled, we twisted, yet it would not come out. I'm thinking I will have to probably get a new tube tomorrow when the dealer opens, but I have to get the old tube out first.
Is all that is holding the tube into the flange is an o-ring?
BTW it's an E-99, not that it should matter.
  #156
Old 02-07-2016, 07:08 AM
Hey dude, it sounds stupid but did you check to see if there are threads in the flange and on the dipstick? Hope you get her.
  #157
Old 02-07-2016, 07:15 AM
Quote:
All the pictures and all show it as just pushing in. With the bends in the tube, I don't think it would turn.
  #158
Old 06-09-2016, 05:10 PM
grif95's Avatar
grif95 grif95 is offline
grif95 is starting off with a positive reputation.
Any new users?
Has anyone installed one of these and have pictures of the process? Would you go this route again ($300)? Are there any new products that address the dipstick tube leak?
A little backstory.....I recently acquired a 7.3 Excursion and after changing the oil (T6 synthetic) I noticed a slight oil leak originating at what looks like the point where the dipstick enters the pan. No, I haven't touched the retainer nut since I read that usually makes things worse. I just would like to fix the problem before it gets too bad. Right now it is a few drops per day.
  #159
Old 06-09-2016, 10:04 PM
brian42's Avatar
brian42 brian42 is offline
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
I had some weepage around the flange. Several factors (time, money, cajones, and reading that it may not fix the problem) drove me to another alternative. I bought a new o-ring for the dipstick tube and then had at the flange with Motorcraft TA-31. You can get it here:
Motorcraft TA31 RTV Silicone Sealant
It comes out very tacky (you need a caulking gun) and reminds me is designed for use specifically on our engines. It's not pretty (I do not have any certifications to slather goop) but it has been effective (tube is back in but the starter is still out):
  #160
Old 06-10-2016, 06:49 AM
grif95's Avatar
Hey, that's a pretty neat mess😜.
How long has your repair been in place? Did it stop the leak completely?
  #161
Old 06-10-2016, 09:14 AM
clem1226's Avatar
clem1226 clem1226 is offline
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
I did the same thing. New oring and flange were a failure so I Just slathered it in " the right stuff(permatex product)" and it has been dry as a bone ever since. 5 years, 150k and holding.
  #162
Old 06-10-2016, 01:08 PM
grif95's Avatar
Quote:
What did you clean the pan with before applying the sealant to get a secure bond?
  #163
Old 06-10-2016, 02:33 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
A good degreaser and scuff up the metal with some 180 sandpaper then wipe it down with isopropyl alcohol then seal it.
  #164
Old 06-10-2016, 08:14 PM
KJNDIVER's Avatar
KJNDIVER KJNDIVER is offline
KJNDIVER has a very good reputation on FTE.KJNDIVER has a very good reputation on FTE.KJNDIVER has a very good reputation on FTE.
I bought this kit bout 2 yrs ago when i noticed the leak on mine. It sat in the corner until about 3 mths ago when the leak was bad enough that I said, damn, i gotta fix that, its pretty damn bad now. Took a little time, but pretty straight forward and no leaks after about 10k miles.
Oil Level Gauge Adapter Repair Kit for 1994 - 2003
  #165
Old 06-12-2016, 10:31 PM
brian42's Avatar
So far so good but it's only been about 500 miles since I did the "repair".
I used the TA-31. It's definitely more expensive but it's designed specifically for the 7.3L (it says so on the tube so it must be true!).
Quote:
I used a lot of brake parts cleaner and elbow grease. When I was done I used some 200 grit sandpaper to rough it up a bit then some more brake parts cleaner. Once it was all dry I loaded up my caulking gun and proceeded to create some driveway mechanic art.
NSRA Northeast Nationals Show Pictures GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 10-10-2012 09:46 AM
56 F100 Progress gquinn8516 1948 - 1956 F1, F100 & Larger F-Series Trucks 104 12-02-2010 07:16 AM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 12:02 PM
Some pictures of the Body Work Red Ford Truck Ontario Chapter 27 07-26-2009 08:12 AM
Dual exhaust pics Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-12-2009 08:50 AM
Tags
1999, 73, diesel, dipstick, f250, fix, ford, leak, leaks, oil, powerstroke, rendezvous, replacement, tube, tubes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
