Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-05-2007, 10:27 PM
schopmer schopmer is offline
schopmer is starting off with a positive reputation.
98 Expedition 5.4L DTC 1131, 1151, 0171, 0174
Here's my situation. About a week ago the cel light lit up and the vehicle started idling rough, but it still operated fine when going down the road. So I took it to a local mechanic to read the codes. Readout discovered two codes,
DTC P0171
system too lean
(bank 1)
DTC P0174
system too lean
(bank 2)
The guy said both sides are lean, so the problem must be somewhere in the middle. He recommended cleaning throttle plate as a start. Which I did, and while in the process I went ahead and changed the throttle positioning sensor (which was probably not needed). After I did that I started it with no idling improvements, but here is my first question.
Question #1 - Should I have disconnected the battery after cleaning and new throttle sensor? If so, should I go ahead and do that before I continue?
So I was busy the next few days with no chance of getting it back to him. I still ran it with the same problem at idle. I finally got it back to him to find out now that I have four codes reading, and he wasn't going to be able to get to it until next week. He also said the the engine would Idle fine for a period then it would start idling rough and jump back and forth like the engine computer was cutting in and out.
DTC P1131
Insuff. Switching
Control Valve
Sensor/Lean
DTC P1151
H02S Bank 2 Sen 1
Insuff. Switching
Lean Mean
DTC P0171
System Too Lean
(Bank 1)
DTC P0174
System Too Lean
(Bank 2)
I have read some similar threads and sounds like I need to check PCV hose connection, clean the MAF sensor, and look for air leaks. I also read about an Automatic Idle Control Valve, but I am not for sure what/where that is and I also wondered if that is the same thing as the throttle position sensor from the description of it in the thread.
I know I have a lot questions, but any advice would be greatly appreciated. Thanks
  #2 (permalink)
Old 07-05-2007, 11:05 PM
DM-03_6.0 DM-03_6.0 is offline
DM-03_6.0 is starting off with a positive reputation.
i had a similiar problem on my truck but when i scanned for the CEL it just said it was an O2 sensor
__________________
2004 F-250. V8 Auto ScSb with some goodies
1980 Jeep CJ-7 Golden Eagle in progress. Matkins Frame Dynatrac 60's 38.5x15 boggers and more...
  #3 (permalink)
Old 07-06-2007, 07:44 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
Welcome to the forum
It is running lean. Check the PCV hose elbows. They are known to crack and suck air, especially the on at the rear of the intake manifold. Next, try cleaning the MAF. If dirty, it will not properly measure the airflow across it and cause a lean condition. Just spray the two small filiments with brake parts cleaner. Do not touch them.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 07-06-2007, 08:04 PM
therrera60 therrera60 is offline
therrera60 is starting off with a positive reputation.
pcv
check the small hose on top of your head cover(passanger side) on the pcv,that one goes to your(carb looking thing)is like a 3 way hose,many times that is broken and absorbing air and that will give you all those codes,hope this helps
  #5 (permalink)
Old 07-07-2007, 04:52 PM
The back elbow was cracked and the others were soft and collapsed. Changed them and it is running with no problems and no cel light. I went ahead and changed the PCV valve while I was at it, around $15.00 to fix it.
Thanks for the advice
  #6 (permalink)
Old 07-07-2007, 06:14 PM
LxMan1's Avatar
Glad to help
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #7 (permalink)
Old 12-04-2008, 02:58 PM
waskier waskier is offline
waskier is starting off with a positive reputation.
My dealer cant find this elbow. Does anybody know the part #?
  #8 (permalink)
Old 12-04-2008, 06:35 PM
jayhoy's Avatar
jayhoy jayhoy is offline
jayhoy is starting off with a positive reputation.
Sounds to me like a faulty 02 sensors,if you can get a hold of a good scanner you can watch the voltage readings of the o2's.
  #9 (permalink)
Old 12-04-2008, 09:39 PM
Does anybody know the part number for the PCV hose elbows?
  #10 (permalink)
Old 12-05-2008, 03:40 PM
Elbow part number
Sorry, I never found out what the part number is for the elbow. I just took it off and matched it up with one in stock at my local autozone.
Tags
0171 , 0174 , 1131 , 1151 , 1997 , 54l , code , dtc , engine , expedition , ford , o2 , obd , p1131 , p1151 , sensors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
