baz used a regulator on the heater lines that came factory outta i think a 351 ford. Worked pretty well to help keep the coolant rollin through the4 lines when the system was off.
So many secrets, so many many secrets, hahaha. Those things are what keep me head of the pack. Rabbit Mfg. is a local company that does all my diesel wrench turnin and he does all my fuel system mods except my injects, although he did install them. Guys good, almost to good to be true. The mod FPR has been ported to secret specs and it is now able to handle anything over 85psi were a stocker wont. The fuel bowl has also been ported and enhanced to secret specs but lets just say that Idle is much smoother and its way quieter as well. The lift pump is my secret and I cant give that one out at all. The CCV mod on my truck is a dual kit, both sides, and its one off.
