Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-05-2007, 05:14 PM
73F100*8Mile is starting off with a positive reputation.
Distributor Curving
Has anyone at all on this forum ever had their distributor re-curved professionally? Or does anyone on this forum themselves own a Distributor tester/curver?? I need my dizzy recurved but as I'm sure most of you know, this is quite the dead art as dizzy'less forms of ignition have taken over. There is a guy on this forum by the name of PerfDistibutor or something of that who sells recurved dizzy's but his company cannot recurve other distributors other than their product. To me I would think it would be an easy 50-75 dollars side cash for the company to make but anyways I need my dizzy curved and can't find a soul on earth to do it. Does anyone here have a dizzy curve machine they would like to part with? I would also be interested in one of those as I know some others who could benefit. Thank you!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-06-2007, 07:52 AM
beetle is starting off with a positive reputation.
I had my 1985 460 distributor re-curved many moons ago by a place here in San Diego called the Dyno Shop, it made a noticable improvement in terms of "it just ran better". I would suggest looking for a shop in your area that has a chassis dynomometer, chances are they have a machine that can do this. If your really desparate, you could ship it out.
  #3 (permalink)
Old 07-06-2007, 01:06 PM
mark a. is gaining momentum as a positive member of FTE.
What problems are you having with it ? What kind is it ? What all was done to the engine? What fuel do you run ? Recurving a dizzy should be done to your application a lot of things come into play. What works for one truck won't necessarially work for yours.
__________________
'79 F250 13" lift 42" Super Swampers
  #4 (permalink)
Old 07-07-2007, 12:35 PM
Jeff Fisher is starting off with a positive reputation.
I had my 84 460 dizzy recurved by Jeff at Reincarnation, he wrote an excellent article on how to recurve a ford duraspark dizzy yourself. Without a machine to spin it on I just had him do it for me. I provided my motor specs, gearing info, how it would be used and he set it up. Made a significant improvement on how it pulls the hills in CO. What I actually paid for was a remanufactured dizzy recurved by him, as in, he provided it and shipped it to me. The web site is listed below for the do it yourself part, or contact him and see what he can do for you, it was well worth it.
http://www.reincarnation-automotive....ons_index.html
The specs mine was set to:
500 = 0
1000 = 3
1500 = 8
2000 = 14
2500 = 20
12 deg @ 18" vacuum
set initial to 14 to 16 deg BTDC
Good luck,
Jeff
  #5 (permalink)
Old 07-07-2007, 12:46 PM
Its in a 1973 F100 2wd, 390 rebuilt from a 360 (360 dizzy is what I have), Holley 600 vac sec, crane 34941 cam, stock valve timing, 93 oct (hoping to go to at least 89 when timed correctly), truck is 3500gvw, 2.75 gears behind a C6 3spd auto. I'm def gonna have to get another dizzy now b/c one day it is very likely that i will change my gears again and if so I'd have to recurve the dizzy again and I need a quick way to do that. What kinda dizzy options are out there that are painless at adjusting the curve? I would like to keep this under $300-400 if possible. I'm not looking for a hot shot .55 gap on my plug, just a reliable tuneable dizzy.
  #6 (permalink)
Old 07-07-2007, 01:45 PM
Social Outcast
petes79f150 has a good reputation on FTE.petes79f150 has a good reputation on FTE.
http://www.msdignition.com/2006/06-8.htm
Around $400, but probably the easiest to adjust, with great tech support.
Pete
__________________
The Hurrier I Go, The Behinder I Get.
  #7 (permalink)
Old 07-07-2007, 05:48 PM
well i tell ya pete, if that one was offered for a 390 FE I'd grab it but it doesn't seem so.
  #8 (permalink)
Old 07-07-2007, 07:52 PM
Alright guys, theres the guts to my distributor. I found that the dist was setup to run on the 18L which meant 36 total plus the initial which would be way to much if it was set around 10 like it would like it. I took the arms and swapped them and set it to where it now rides on the 13L and then spun the dist 180 degrees to get her back at #1. I'm not sure at all what the G2 and G1 weights mean but at least I've got some knowledge as to what I have. Also noticed the two springs. One is definately shorter than the other. When both are installed, the longer springs doesn't even begin to grab by the time the 13L has maxed out with the smalled, shorter spring. So it looks like someone has been in here before me in the last 34 years...who'da thought. So at this time I'll take any thought/comments as to what springs I should purchase. Can I run with just the one spring right now or will it advance really quickly w/ half the spring like I'm thinking?
[img]file:///C:/Documents%20and%20Settings/Alan/Desktop/Pictures/PB020095.JPG[/img]
  #9 (permalink)
Old 07-07-2007, 07:55 PM
Well obviously the pic didn't work and i have no idea how to make it work... ...lemme see if i can post it in my gallery.
  #10 (permalink)
Old 07-07-2007, 09:17 PM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Pictures on your computer can't be accessed from the web. Check with the user gallery forum for help.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
  #11 (permalink)
Old 07-07-2007, 10:07 PM
Ya i know that, when i wrote the reply, the pic was in the post. Instead of the pic being in the post when i posted it, it showed what you see so i went ahead and loaded the pic in my gallery. Take a look see and tell me what you think.
  #12 (permalink)
Old 07-08-2007, 09:11 AM
You can try it with the one light spring but the curve will probably come in too quickly for your aplication = pinging. The weights you have are stock. I have never seen any aftermarkets offered. I run mine with 2 of the stock light springs. You can certainaly do some experimenting with making the slot longer / shorter.
__________________
  #13 (permalink)
Old 07-12-2007, 04:40 AM
HemiEater's Avatar
HemiEater is starting off with a positive reputation.
  #14 (permalink)
Old 08-06-2007, 07:41 PM
just-n-time's Avatar
just-n-time is starting off with a positive reputation.
try to look up a tec school in your area they most likely will still have the machine to do your recurve
  #15 (permalink)
Old 08-06-2007, 07:47 PM
Wink Spring kits
you can still buy spring kits from sumit,give them a call
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
