Surge Tank Leaks
Surge Tank Leaks
Some time ago I posted about a pin hole leak developing in the joint where the waterneck is soldered to the bottom of the brass surge tank. I thought I found the pinhole and tried sealing it up with marine grade epoxy which didn't work. As there are no real radiator shops in my area that can repair the tank, I have ordered a replacement from Greg Donahue (Greg advised that vibration is what causes the cracks and to make sure that the upper radiator hose is not pressed tight up against the side of the surge tank (mine is) or radiator).
I have used the gas tank repair sealer sold by POR-15 to restore and seal my gas tank. I talked to POR-15 about using the same sealer on the inside of the brass surge tank. The tech advisor said that it would work. He said I should follow the instructions (Marine Clean to clean out the tank, Metal Ready to etch the inside of the tank, and then the sealer). He said that the sealer is impervious to coolant and will withstand heat (when cured) of up to 600 degrees F.
Have any of you tried this? Does it sound like a reasonable thing to do? Can anyone think of any problems it could cause?
Thanks in advance.
Thanks in advance.
Its a do it yourself kit.
Costs about $50.00. Yes, I have a torch. Yes, I have soldered/brazed on the surge tanks before. The problem for me is I would want to do every seam to make sure they don't leak. Not sure my skill level is up to that, and there is no one left in my area (Northern Virginia) that does that sort of radiator work. All the old time radiator shops have been shut down.
I used it on my Marine tanks. It works well as a combo ro clean prep and seal a tank. However I cant confirm the heat part sorry. I can however advise on a few things.
1. Wash out the metal etch very well and use a fresh air souce to "thoroughly" dry the tank prior to adding sealant. Dont get in a hurry.......
2. Under no circumstances do you want to put the lid back on the container of sealant. "It will explode" I'd get the smallest kit they sell.. the metal ecth qt is more than enough "much more" and any extra sealer is just trash.
BOL
BOL
BOL
BOL
I'm thinking that if the POR 15 is flexible enough to maintain it's bond through the thermal cycles, the existing metal should help maintain the structural aspect of the seal.
I have $275 stuck on my brain...for a new tank that leaked? I think if another $50 makes it useable, I'd be squeakin to the seller about it.
My thoughts? This is on a Galaxy and not a truck, right? So no chance of switching to a radiator with a big top tank ?
Other ideas:
Don't want more pinholes? Use a good coolant, and change it at LEAST every 2 years.
Vibration is a good thing to think about ... but that would usually crack something, not cause pinholes. Pinholes sounds like corrosion.
I wouldn't seal a tank that doesn't have any holes Just be kind to it
Other ideas:
Yes. 64 Galaxie 500 convertible. I can get a radiator from Crites that eliminates the surge tank, but it is pricey and not the look I am after. Other than the leaks, I have no cooling problems on even 90+ degree days (my limit for driving a non-air conditioned, black vinyl interior convertible. LOL).
Oh, the coolant (Prestone) get changed almost anually (this will be my fourth surge tank in five years).
I am hoping that installing the upper radiator hose as Greg Donahue recommends will help.
Originally Posted by krewat
Uh, you shouldn't get any pinholes in anything changing it THAT much
I wonder - electrolysis eating away the metal somehow? Is it even possible that the tank is not electrically connected to the block somehow/someway?
WALFORD'S 56
11-15-2014 11:11 AM
RV_Tech
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-06-2014 06:11 AM
dustyroad
07-21-2014 05:51 PM
66F250CS
06-11-2013 10:58 AM
