Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-05-2007, 03:54 PM
MENESLIS is starting off with a positive reputation.
Ac Stopped Working
Hey guys, just yesterday my AC stopped working, fan blows and heater still works. I opened up the hood and noticed that the AC CLUTCH/COMPRESSOR does not engage. Is the AC clutch suppose to engage once in a while or do nothing? I've checked my fuses and all are fine. I could use some info, thanks.
99 Eddie Bauer Expy 5.4L
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-05-2007, 05:35 PM
wchain is starting off with a positive reputation.
DId you check the 'fat man pants' fuses? (big square deals, under the hood in the fuse box, usually pastel colors, pink, yellow, etc).
Also you can try to run a 'self diagnostics' on the EATC Brain, see if it comes up any codes.
  #3 (permalink)
Old 07-07-2007, 08:11 PM
projectSHO89 has a good reputation on FTE.projectSHO89 has a good reputation on FTE.
1) Measure static charge with a gauge. You must have a minimum of 45 psi (80-120 is desired) in able to initially "make" the pressure switch. If good, go to step 2.
2) Locate the cycling switch on the accumulator can on the firewall. Disconnect the connector and insert a jumper into the harness connector. If the compressor clutch engages, the switch is bad.
3) With the jumper still installed and the engine running and the AC turned on, hit the face of the clutch with a rubber mallet or a broomstick. If it engages, the air gap has worn too much. Remove a shim.
Beyond that, you're going to need more in-depth troubleshooting which will require a meter and a lot more digging around.
The three items above will usually account for more than 80% of AC failures in F-series and the ExpyGators.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
