HPOP/ Anti drain back valve - Ford Truck Enthusiasts Forums
Old 07-05-2007, 01:44 PM
Wcpaz Wcpaz is offline
Wcpaz is starting off with a positive reputation.
Does anyone have a drawing of the HPOP 2001 7.3. I seem to be loosing oil from the HPOP and the truck will not start untill I fill the HPOP resivoir,I need info on the anti drain back valve.
Old 07-05-2007, 02:27 PM
nedaclu nedaclu is offline
nedaclu is starting off with a positive reputation.
try www.7point3.com click on common mod/maintaince/guide. this might help if not for this it is a good page to keep in mind.
totin_tools's Avatar
totin_tools totin_tools is offline
totin_tools is gaining momentum as a positive member of FTE.
check your lines going out of the hpop to the heads. same issues I was having and then the line on the passenger head blew a hole in it.
Old 07-06-2007, 09:20 PM
Mach1 Mach1 is offline
Mach1 is starting off with a positive reputation.
LPOP..Cheeck out that guy..Most of the time this is the culprit..
Old 07-06-2007, 09:42 PM
Uzumati's Avatar
Uzumati Uzumati is offline
Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.
The HPOP reservoir is fed from the drain back valve on initial/cold starts, but like mack 1 said the LPOP is what feeds the drain back valve. If the oil gauge on the dash is taking longer than 3 seconds to rise to the normal level it is a sign that the LPOP is not up to snuff.
Here is a recent thread on the valve which if it has debris in it can cause the reservoir to leak down overnight. If you check the level prior to cranking the first time of the day and it is low look to the valve. If the reservoir is full and empties while cranking look to the LPOP.
http://www.ford-trucks.com/forums/62...ght=Drain+Back
HPOP Prime Amount?? IT STARTED!!!!!!!!!! syjl 1994.5 - 1997 7.3L Power Stroke Diesel 14 01-26-2016 06:00 AM
Drain the HPOP to change IPR? bigcountry1009 1999 to 2016 Super Duty 0 12-25-2014 09:42 PM
HPOP res drains after HPOP failure. bulla 1999 - 2003 7.3L Power Stroke Diesel 32 02-26-2011 12:38 PM
Seriously, How does HPOP recirculate oil..... Iallwork 1994.5 - 1997 7.3L Power Stroke Diesel 43 12-12-2010 05:44 PM
HPOP oil reservoir John Henderson 1999 - 2003 7.3L Power Stroke Diesel 8 12-29-2005 09:57 AM
Tags
60, 73, anti, back, check, drain, drainback, drained, ford, guide, hpop, number, oil, part, res, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
