new guy here needs some quick advice
Well I got a 89 F-150 4x4 that didnt come with a tranny, transfer case or axels. I recently came across an 87 f-150 4x4 for parts. Only thing I think they had different trannys c6 and 4eod? 87 has the 3 speed and 89 had overdrive.
What would it take to convert the 89? Should I just go find another parts truck? Will the transfer case work if I get the other tranny and im guessing I will need other axels.
How hard is it to sell parts on here so I can offset the cost of what I have to buy?
Thanks for any help.
Same axles same tranny and same t-case should allbolt up just right.Only issue you might have would be driveshaft...unless they are the same truck except for the transmissions.I don't believe they started MAF until the early 90's...I might get corrected on that but........anyways, same frontend same rear same t-case and the tranny should work great.....you'll need the comp for the other truck if the E4OD is what you're going to be using...it's computer controlled....the C6 isn't.....it's all mechanical so it should be just plug n play like Linemo said....
Opps said axels meant to say driveshafts. Also im puttin a C6 into the 89 which had the overdrive tranny. How about the sacrifice in mileage? How much worse is it without overdrive? So C6 swap will work no problem just a bolt in?
Thats good to know if I opt to just use that drivetrain.
Thanks
Thanks
on
sverker
11-12-2011 06:03 AM
Lead_Foot
06-16-2005 05:31 PM
77_400
10-24-2001 08:48 AM
