What axle would be in a 95 F350 SRW 2WD truck. Also, would it be a desirable axle to swap into my 79 F150 when I swap my 460 into it? (still on the hunt for the front D60)
Sterling 10.25"! very desirable! i have been running one in my bronco with 39 iroks and have yet to break it! kubota has been running one in his rig with a very healthy 460 and 44 tsl's!
DO IT!
-cutts-
__________________
Quote:
Originally Posted by Ingolf
yeah, im a rich kid. but hey, i dont hate my parents for it. my dad drives a lambo.. so what the **** do i care LOL
The last year for a Dana 60 in a Ford truck was 1984. It was Sterling axles from then on.
__________________ Nathan TM
You may have an Effie but I have a Emmie!
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
That is sitting on a '78 F-250 Supercab frame with F-350 axles.
Built to play and work hard! Frame Swap Tech Article
I have one over in VA that I can make you a deal on. I was going to swap it into my F150, but have gone another route and will be building another rig and leaving that truck the way it is. My Sterling is from an 89 f-250, with 4.10 ratio. Send me a pm if you are interested, if not ebay it goes....
__________________
Karl
I'm the Voice of Reason
FTE - Where signatures get edited with no explination why.
Duh.... I re-read your original post. If you have access to the 95 F-350 rear locally, go for that. It is the same as what I have and you are right shipping cost on this heavy rear will be nuts.
__________________
Karl
sterling 10.25's are a dime a dozen. dana 60's are the hard to get ones. your best bet is to buy a non running f-350 4x4 and take the axles off. it will probably be cheaper to go that route and rebuild the axles then getting them separately and maybe having to rebuild them.
Fat chance of that happening around here. They are rare around here, and the ones that are here, the owners know what they're worth, so the prices are through the roof
does that '89 10.25 have the VSS on it? My dad needs a new rear for his '95..
Yes it does, I was originally going to put it into my 95 F-150 and keep the speedo working, but I am going another route and leaving the 8.8 in it for now. I live down in VA, so if you want to look it over let me know as I need to get rid of it fairly soon...
__________________
Karl
