Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-24-2002, 08:01 PM
mustange70's Avatar
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
351M engine swaps
__________________
Cody, Calgary
AB Chapter Leader
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-13-2002, 09:39 PM
Crazy Canuck is starting off with a positive reputation.
Post 351M engine swaps
What would all be involved in swapping a 351M for a 351W or an FE in a 1977 F-150. Would significant modifications need to be made or not.
  #3 (permalink)
Old 08-14-2002, 12:28 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
351M engine swaps
Transmission/or bellhousing would have to be changed for all the engine senarios you listed.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 08-14-2002, 10:42 PM
351M engine swaps
What I really wanted to know was about the motor mounts. Would mounts for a 351w or an FE simply bolt in? By the way it is a 2wheel drive if that makes any difference.
  #5 (permalink)
Old 08-15-2002, 01:23 PM
Franklin2's Avatar
351M engine swaps
All those motors where available in that style frame, so with the correct motor mount they should bolt in. But there's lots of other stuff to consider like correct oil pans/dipstick locations, exhaust manifolds, and some of the smaller motors weren't available in a 4wd. I believe some of the guys on here have been having trouble finding headers or are having to make a custom exhaust for 4x4 trucks with the 351w/302 combinations for those years.
__________________
Dave F
  #6 (permalink)
Old 08-15-2002, 10:54 PM
351M engine swaps
Thanks for input.
  #7 (permalink)
Old 08-22-2002, 12:29 PM
Brad Deicke is starting off with a positive reputation.
If the engine your swapping is out of a 4x4 you might have to change the pan and make your oil pump a front sump, instead of the rear sump.
-Brad
1970 F-250 2wd 4sp. 360FE
1979 F-250 4x4 4sp. 400M
  #8 (permalink)
Old 08-23-2002, 01:36 PM
blu93gt is starting off with a positive reputation.
351M engine swaps
[updated:LAST EDITED ON 23-Aug-02 AT 01:37*PM (EST)]it would be easier to swap a 400 crank & pistons into the 351M, and make more power too!
__________________
Brad
'01 Sport-Trac
'75 Ranchero 500
'93 Mustang GT
  #9 (permalink)
Old 08-24-2002, 12:23 AM
Brian460 is starting off with a positive reputation.
351M engine swaps
Your best bet would be as stated above is to make a 400, or if you do want to swap engines go to a 460 that will use the same trans.
Then you can use the money you would have spent on a different trans. to get the proper motor mounts, oil pan, etc for the 460.
Brian
__________________
Brian
'03 F-250 FX4 CC SB 6.0L Powerstroke
SCT X3 with Spartan Tunes
4" Superlift
4" Magnaflow
X-Monitor
315/75/16 BFG MT KM2
American Racing
4.30's
PSD Burnout
www.thequackshack.net cb radio forum
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
